Raptor problem. Keeps resetting
I broke my own rule and called a method from ProgramStarted();
I always use a button to allow the program to continue any other action.
Well… almost always.
Now I am in a BIG HURT becaues I didn’t use the button approach!
My Raptor keep resetting in a loop because of a small bit of code.
//Called from ProgramStarted()
private void test()
	try
		byte[] byteArray = new byte[] { 0x30, 0x31, 0x32, 0x33, 0x34 }; //0-4
		string byteString = System.BitConverter.ToString(byteArray); //Raptor resets
		Debug.Print(byteString);
	catch (Exception e)
		Debug.Print(e.Message);
Using BitConverter crashes the Raptor causing it to reset.
I got in a hurry to try and find the problem so I made another application to do some testing.
My test app did not use the button and I called test() directly from ProgramStarted().
When BitConverter crashes my Raptor would display the following on my T43 and resets itself.
Displayed on T43
Build Date: Jun 26 2015
10.10.04
cps=0x000000df
pc=0x20iec974
Ir=0x20iec978
sp=0x00307658
I am using:
2015 R1 Pre-Release 3
NETMF SDK 4.3 QFE2
Firmware 4.3.7.9
Does anyone know of a way to save my Raptor?
FEZConfig never sees my raptor and trying bootloader does not work either.
Pin 8 Socket 3 to ground reset brings up Bossa Program Port (COM5) but FEZConfig cannot connect to it.
Connecting to device COM5.
Please wait, this may take a few moments
Failure - Device is not connected or not responding.
Have you tried MFDeploy?
@ Mike -
Thanks …
Tried it but the same thing.
Cannot connect to the Raptor.
Guess I must get a new Raptor…
What do you see in Device Manager when you try to put it in bootloader mode ?
@ andre.m -
but sam-ba is the right one
Not sure, but I believe that this is the first time I saw the Bossa Program Port. I thought it had something to do with 2015 R1 Pre-Release 3.
I have never used sam-bd directly so I would have to research it. Is there info here that you can direct me to?
As a note: My Raptor is up and running.
I Have no idea why but it finally showed up (and stayed there) in Universal Serial Bus devices as G400.
In desperation…
I quickly pressed/released the LDR0 and LDR1 buttons (and at the same time quickly pressed reset) many times.
FEZConfig finally connected to the USB port and I was able to reinstall the firmware.
Thanks!
@ andre.m -
Thanks for the link.
I was aware of that document and I have always used FEZConfig with success on my Raptor
@ willgeorge -
I prefer there should check status of a button before doing anything when coding. After everything is done well then remove that button.
@ Dat -
I usually use the button approach. But for some reason did not.
Is there any information about BitConverter? Is it useable at all with the new SDK and Firmware?
@ willgeorge - BitConverter is part of Microsoft’s code in NETMF, we don’t change any of it, so it’s likely a bug with them. To be sure though, you can always test it on another board.
The Bossa programming port is used to update TinyBooter with the script found at C:\Program Files (x86)\GHI Electronics\NETMF v4.3 SDK\Firmwares\G400\Update Loader.bat (for the 2015 R1 SDK).
When you do deploy a program that crashes the board, you can hold down LDR1 I believe to enter TinyBooter mode. From there, you can use FEZ Config to erase your application.
@ John -
Thank you for the update…
you can hold down LDR1 I believe to enter TinyBooter mode. That must be why I finally got my Raptor working again.
I was banging on LDR0 and LDR1 while pressing the reset button.
