Hello TinyCLR community,
I am new to Gadgeteer and to C# programming, my background is in HW and I see the Gadgeteer system as a means to developing my programming skills.
Before I go any further if anyone is beginning to learn C# like myself then have a look at the videos on Channel 9: C# Fundamentals: Development for Absolute Beginners | Microsoft Learn
They were very helpful to me and I hope they help you as well.
I am trying to write a bit of code to generate a random number between 1-100. The first code snippet below works when I generate a standard .cs file however when I am programming within a Gadgeteer template the code does not work (ERROR: No overload for method ‘Next’ takes 2 arguments).
I understand that the .NET Gadgeteer uses the .NET Micro Framework which is a subset of the .NET platforms. I suspect that this is the reason why the code isn’t working, am I right? And can anyone suggest a method to generate a random number using .NET Gadgeteer? I have been scouring the net but the valid solutions are for standard C#.
Thanks in advance to all
