I have completed a BME280Device class which provides a driver for the Bosch Sensortec BME280 device supporting I2C and SPI. My driver only supports an I2C connection. The driver works well. I want to make it available by posting it.
However, I started thinking about some issues on which I need some clarification. Because the BME280 consists of a temperature/pressure/humidity sensor, it lends itself to being paired (on the same I2C bus but with different addresses) for an indoor/outdoor data measuring application. As such, this means two (or more) BME280 I2C devices (plus potentially I2C devices of any other kind) on the I2C bus.
Because the I2CDevice uses a shared resource i.e., the I2C bus, (really the two ports that control the SDA and SCK lines for the I2C bus), what prevents attempts by other threads in an application to attempt to access more than one device on the I2C device at the same time?
When I first looked at the I2CDevice.Execute method:
public int Execute ( I2CTransaction[] xActions, int timeout)
My naive thought about the reason for the timeout parameter was that it comprised a timeout that would return (without exception) if the device failed to complete the handshakes required to implement the actions in the I2CTransaction array within the timeout period. But the help information about the Execute method says the following:
Executes a transaction by scheduling the transfer of the data involved.
So the I2CDevice.Execute method [em]schedules[/em] the execution of the transaction. Does this mean that the Execute method waits for any existing I2C bus transaction on the shared I2C bus to complete before starting the execution of the designated transaction, and only for the duration of the timeout? If so, then my driver does not need to concern itself with competition for use of the shared I2C bus with other threads in the program.
If the I2CDevice does not serialize the flow of data on the shared I2C bus, it means I must add more logic into the driver to serialize access the the shared I2C bus (at least for threads accessing BME280 devices).
The help documentation does not say what will happen when a call to I2CDevice.Execute fails to properly execute at the bus level. The Execute method reports the number of bytes transferred on the bus when returning from the command. Is this how one determines whether the call to the Execute method succeeded or failed? Or is an exception thrown? The documentation does not mention anything about an exception from the Execute method.
Without any definitive guidance from the help information on the I2CDevice.Execute method, should I assume that the timeout parameter controls how long the I2CDevice object will wait for the shared I2C bus to become idle before executing the Execute method? Should I assume that I2CDevice.Execute never throws an exception? Should I assume that successful execution of the Execute method occurs only when the result of that method consists of the sum of the bytes in all transactions found in the xActions parameter, i.e., the array of I2CTransactions?
