Application for Raptor using SD and UsbHost
Microsoft Visual Studio Express 2012 for Desktop - Update 4
Microsoft .NET Micro Framework 4.3
My Raptor info:
Loader (TinyBooter) version information:
4.3.3.0 on this computer and device.
Firmware (TinyCLR) version information:
This is only a general question and not really a problem but I would like to use:
FileInfo fInfo = new FileInfo(“some file name”);
I would like to know why this exception occurs…
//Called on power on/reset if SD Card is inserted
void sdCard_Mounted(SDCard sender, Gadgeteer.StorageDevice device)
FileInfo fInfo = new FileInfo("\\USB\\Application.config");
bool test = fInfo.Exists;
if (test == false)
{ return; }
//Also if using
if (!fInfo.Exists)
{ return; }
//Try/Catch does not catch any exception
try
if (!fInfo.Exists)
{ return; }
catch(System.IO.IOException ioe)
Debug.Print(ioe.Message);
Debug.Print(ioe.InnerException.ToString());
Exception System.IO.IOException - CLR_E_INVALID_DRIVER (1)
Message:
Microsoft.SPOT.IO.NativeIO::GetAttributes [IP: 0000]
System.IO.File::Exists [IP: 001a]
System.IO.FileInfo::get_Exists [IP: 0007]
Gadgeteer.Modules.GHIElectronics.SDCard::OnMounted [IP: 0036]
System.Reflection.MethodBase::Invoke [IP: 0000]
Gadgeteer.Program::DoOperation [IP: 001a]
Microsoft.SPOT.Dispatcher::PushFrameImpl [IP: 0054]
Microsoft.SPOT.Dispatcher::PushFrame [IP: 001a]
Microsoft.SPOT.Dispatcher::Run [IP: 0006]
Gadgeteer.Program::Run [IP: 001d]
A first chance exception of type ‘System.IO.IOException’ occurred in Microsoft.SPOT.IO.dll
Only need to know to keep my brain happy…
