Ok, I have noticed that the USB3.0 ports that worked while I was setting things in BIOS are not recognized by Windows.I had to plug keyboard and mouse into old usb ports. Looks like some extra Windows drivers have to be installed. I will try Hydra as soon as I am done with the rest of the setup.
I had installed everything including all the drivers from MB CD. So there are no warnings in the Device Manager. Everything is working great - no issues at all.
No, just tend to hate sitting around waiting for videos to encode. This machine cranks them out like nothing.
Scott Hanselman and I did simultaneous builds with the same key specs. We chose different video cards and memory, but same motherboard, case, SSD, etc. I water cooled mine, he air cooled his.
As it turns out, the motherboard is not great, so I wouldn’t recommend that to others.
This is the first time I’ve set up the Hydra. I plugged it in and it was detected as FEZHydra_Gadgeteer
I tried to deploy something from Visual Studio and it failed. Couldn’t find the defice
So then I tried to use MFDeploy to flash the latest firmware, as the firmware on the device was pre-pre-pre stuff.
Although the FEZHydra_Gadgeteer showed up under USB in MFDeploy, MFDeploy stayed locked for about 10-15 minutes when I tried to ping. It finally came back with “Error: No response from device” (man, that timeout needs to be shorter! Longest. Timeout. Ever. It reminds me of this Kids in the Hall recurring sketch in one episode where he stood outside someone’s house all day yelling for Lopez)
So then I went through the process of erasing it and then reflashing the bootstrap as explained on the Wiki. The log file seems to indicate it succeeded:
-I- Temp file : C:/Users/peter.brown/.sam-ba.testCompareFile
-I- Compare File : FEZ_HYDRA_TINYBOOTER.bin with memory at address : 0x8400 , for 59868 byte(s)
-I- Read File C:/Users/peter.brown/.sam-ba.testCompareFile at address 0x8400
GENERIC::ReceiveFile C:/Users/peter.brown/.sam-ba.testCompareFile : 0xE9DC bytes from address 0x8400
-I- Reading: 0x18C0 bytes at 0x8400 (buffer addr : 0x302CD8)
-I- Reading: 0x18C0 bytes at 0x9CC0 (buffer addr : 0x302CD8)
-I- Reading: 0x18C0 bytes at 0xB580 (buffer addr : 0x302CD8)
-I- Reading: 0x18C0 bytes at 0xCE40 (buffer addr : 0x302CD8)
-I- Reading: 0x18C0 bytes at 0xE700 (buffer addr : 0x302CD8)
-I- Reading: 0x18C0 bytes at 0xFFC0 (buffer addr : 0x302CD8)
-I- Reading: 0x18C0 bytes at 0x11880 (buffer addr : 0x302CD8)
-I- Reading: 0x18C0 bytes at 0x13140 (buffer addr : 0x302CD8)
-I- Reading: 0x18C0 bytes at 0x14A00 (buffer addr : 0x302CD8)
-I- Reading: 0xB1C bytes at 0x162C0 (buffer addr : 0x302CD8)
Sent file & Memory area content (address: 0x8400, size: 59868 bytes) match exactly !
GENERIC::SendFile GHI_OSH_BOOTSTRAP.bin at address 0x0
-I- File size : 0x25E8 byte(s)
-I- Writing: 0x18C0 bytes at 0x0 (buffer addr : 0x302CD8)
-I- 0x18C0 bytes written by applet
-I- Writing: 0xD28 bytes at 0x18C0 (buffer addr : 0x302CD8)
-I- 0xD28 bytes written by applet
-I---------------------------------
-I- Script Completed -
-I- Please Reset the Device -
After erasing the Hydra (using the socket 3 jumper approach), it showed up as COM11 as a camera device. After flashing the bootstrap, the Hydra wasn’t redetected as anything else.
I hooked up a button to socket 14 and pressed it while holding reset.
Pinging via MFDeploy still fails, so I haven’t been able to deply the netmf firmware
Is this what you’re seeing, or did I botch some other step?
(intel Core i7 980x stock is 3.33ghz, running at 4.2ish, Win7 x64)
