Question about using SD card in OSHW
Hello,
I’m trying to use my SD card on the FEZ Cerbuino and it works fine when the card is plugged in. But i was wondering of there is a way to check of the card is present or not with the OSHW version?
I have found there where some possibilities in the Premium version, but i do think that i over looked the options for the OSHW. Did i?
my current code looks like:
          GHI.OSHW.Hardware.StorageDev.MountSD();
            if (VolumeInfo.GetVolumes()[0].IsFormatted)
                _root = VolumeInfo.GetVolumes()[0].RootDirectory;
            if (File.Exists(_root + @ "\config.json"))
                var sr = new StreamReader(File.OpenRead(_root + @ "\config.json"));
                text = sr.ReadToEnd();
                sr.Close();
                DeviceID = Guid.NewGuid();
                CurrentTime = DateTime.Now;
                text = serializer.Serialize(this);
                var sw = new StreamWriter(File.Create(_root + @ "\config.json"));
                sw.WriteLine(text);
                sw.Close();
            GHI.OSHW.Hardware.StorageDev.UnmountSD();
Someone can give me a shot in the right direction. Also I love to see an option that i can detect of the Card is plugged in or is just removed. I know there are options in the Premium as well.
This is what I use on my Cerbuino:
public sdCardHandler(SDCard sdCard)
            _sdCard = sdCard;
            _sdCard.SDCardMounted += new SDCard.SDCardMountedEventHandler(sdCard_SDCardMounted);
            _sdCard.SDCardUnmounted += new SDCard.SDCardUnmountedEventHandler(sdCard_SDCardUnmounted);
            Microsoft.SPOT.IO.RemovableMedia.Eject += new Microsoft.SPOT.IO.EjectEventHandler(RemovableMedia_Eject);
            Microsoft.SPOT.IO.RemovableMedia.Insert += new Microsoft.SPOT.IO.InsertEventHandler(RemovableMedia_Insert);
 #region events
        void sdCard_SDCardUnmounted(SDCard sender)
            // The SD card has been unmounted
            // DO NOT try to access it without mounting it again first
            _isMounted = false;
            DebugPrint("Event Unmounted");
        void sdCard_SDCardMounted(SDCard sender, GT.StorageDevice SDCard)
            // SD card has been successfully mounted. You can now read/write/create/delete files
            // Unmount before removing
            _isMounted = true;
            // Get the root directory
            _rootDirectory = _sdCard.GetStorageDevice().RootDirectory + @ "\"
            DebugPrint("Event Mounted. RootDir : " + _rootDirectory);
        void RemovableMedia_Insert(object sender, Microsoft.SPOT.IO.MediaEventArgs e)
            _isInserted = true;
            DebugPrint("Event Inserted : " + e.Volume.Name);
        void RemovableMedia_Eject(object sender, Microsoft.SPOT.IO.MediaEventArgs e)
            _isInserted = false;
            _isMounted = false;
            DebugPrint("Event Ejected : " + e.Volume.Name);
        #endregion
Did this help?
Sorry, it looks good and I’'m going to test it soon.
Here is a more complete example that you can run directly on the Cerberus:
using System.Collections;
using Microsoft.SPOT.Touch;
using System.IO;
using Gadgeteer.Networking;
using GT = Gadgeteer;
namespace GadgeteerApp2
    public partial class Program
            sdCard.MountSDCard();
            System.Threading.Thread.Sleep(500);
            Debug.Print("Event Unmounted");
            Debug.Print("Mounted");
            writeSDcard();
            Debug.Print("Event Inserted : " + e.Volume.Name);
            Debug.Print("Event Ejected : " + e.Volume.Name);
        void writeSDcard()
            //Get the root directory
            string rootDirectory = sdCard.GetStorageDevice().RootDirectory;
            Debug.Print("Writing to : " + rootDirectory);
            //Use Streamwriter to write a text file
            StreamWriter textFile = new StreamWriter(rootDirectory + @ "\hello.txt");
            textFile.WriteLine("Hello SD card");
            textFile.Close();
thanks
