When booting up a FEZ Spider with a TE35 module attached, the screen initially displays:
EMX
Version 4.3.3.0
Debug: USB1
LCD: 320x240
I realize that a deployed application can just clear the screen as it begins, but there is a delay during which the text appears before the application takes over. I was wondering if there is any way to prevent this initial text from appearing. Is this coming from the TE35 module driver, from the mainboard, or from NETMF? Is there some property available that can be used to disable this text?
Thanks for your reply. I know this may sound silly, but could you provide a pointer to the GHI library reference? This sounds like the document I should have been reading all along.
I found two properties that looked promising, but I suspect that they’re having no effect because they’re getting called too late (in ProgramStarted, rather than during boot). The text messages still appear on the display.
Which one of these should quiet the text messages, if called at the appropriate time? (Or is there a different property that would quiet the messages?)
Where do I need to set the properly early enough in the process to have an effect?
