OK… I’m stumped! or maybe stupid?
I have not been able to solve this issue in my code.
I have several methods that use the SD Card. All is well until I try to write to file.
[Code]
private StreamWriter sw;
sw = new StreamWriter(s, true); //string s is the path
foreach (string Econtent in sarray) //sarray[] is a array of 70 data strings received from my WiFly device (Roving not the GHI device)
sw.WriteLine(Econtent); // The Assert occurs upon the first use of sw.WriteLine();
The LCD goes to a black background with the Assert text message shown and remains that way until the foreach loop is finished.
Upon exit of the loop (a few seconds after) the LCD returns to normal with no loss of any information. The text file saved to the SD Card is written correctly.
If I put a breakpoint at the line ( sw.WriteLine(Econtent); ) and use F5 to continue throught the 70 strings, I do not receive the Assert message and the LCD
remains normal?
I tried using the foreach loop in a different thread but this makes no difference. I still receive the Assert message.
No code is used to access the T35 LCD display while reading/writing the SD Card.
And ideas?
Thanks in advance.....
