Hello there,
I’m trying to make a simple buzzer to make sound with a chipworkx development environment.
I’m using the following code:
PWM pwm = new PWM((PWM.Pin)ChipworkX.Pin.PB4);
pwm.Set(10000, 50);
The design time compiler does not report any errors. Also building is completed without errors. However when I deploy the code and run it an error message pops up with the following error:
[quote]An unhandled exception of type ‘System.ArgumentException’ occurred in GHIElectronics.NETMF.Hardware.dll
[/quote]
I’m using version 4.02 from the GHI SDK. Could someone please tell me what I’m doing wrong?
Many thanks in advance,
Kind regards,
Nick
