I am using the UC5550 and UCM Dev. The tutorial on PWM indicates that the correct controller/channel must be used (not the Default). I want to use PWM B (on the UCM Dev board) . Tracing back on the schematics, PWM B indicates T4C2. What controller/channel is this ?
Timer 4 channel 2. But there pins definitions library should have them listed.
PWM works great.
