I was working on a project and was foiled by a simple pushbutton! It was unreliable despite the glitch filter. It turned out to be a coding error on my part. I’ve re-created it in a simple program below. Can you spot the mistake? If you think this is obvious, please let novice users take a stab. I don’t have any prizes, just your own satisfaction that you’re smarter than me.
namespace DebounceTest
static OutputPort led;
static long counter = 0;
SetupPorts();
Debug.Print("Ready for test. Press the button!");
private static void SetupPorts()
led = new OutputPort((Cpu.Pin)FEZ_Pin.Digital.LED, false);
Microsoft.SPOT.Hardware.Cpu.GlitchFilterTime = new TimeSpan(0, 0, 0, 0, milliseconds: 200);
InterruptPort startButton = new InterruptPort((Cpu.Pin)FEZ_Pin.Digital.Di12, true, Port.ResistorMode.PullUp, Port.InterruptMode.InterruptEdgeLow);
startButton.OnInterrupt += new NativeEventHandler(startButton_OnInterrupt);
static void startButton_OnInterrupt(uint data1, uint data2, DateTime time)
led.Write(true);
Thread.Sleep(50);
led.Write(false);
counter++;
Debug.Print("You have pressed the button " + counter.ToString() + " times.");
