Hi all,
I recently bought a FEZ Hydra together with an PulseInOut module in an attempt, to read 8 PWM channels from a connected receiver.
Altough the basic reading works, it seems every call to ReadChannel takes roughly 40msecs to get a response. This way, I need >300msecs to read all 8 channels. For RC purposes, this is wayyyyyyy too slow.
Am I missing something here? There does not seem to be a possibility to read all 8 channels at the same time, and waiting 40msecs for each reading is, well, hard.
Second point, I bought an IO60p16 along. When I try to access it, VS2010 gives me only “equals, get hash code, get type, reset, to string”, but I found a number of examples where I should be able to access more. More meaning something useful with port read and write.
Again, I suppose the error is on my side, but I can’t seem to grasp what exactly is wrong?
using System.Collections;
using Microsoft.SPOT.Time;
using Microsoft.SPOT.Touch; // I import some more modules than necessary since I also try to use a T35 later on...
using Gadgeteer.Networking;
using GT = Gadgeteer;
namespace GadgeteerApp1
public partial class Program
int[] pwmhigh = new int[8];
DateTime millistart;
DateTime milliend;
GT.Timer pwmReadTimer = new GT.Timer(100);
pwmReadTimer.Tick += new GT.Timer.TickEventHandler(pwmReadTimer_Tick);
pwmReadTimer.Start();
void pwmReadTimer_Tick(GT.Timer timer) // Variant 1, reading only PWM Channel 1
millistart = DateTime.Now;
pulseInOut.ReadChannel(1, out pwmhigh[0], out pwmlow[0]);
milliend = DateTime.Now;
var millis3 = milliend - millistart; // Here I get something between 30 and 40msecs (mostly 32-33, small peaks up to 40)
void pwmReadTimer_Tick(GT.Timer timer) // Variant 2, reading all 8 PWM Channels
for (int i = 1; i <=8; i++) {
pulseInOut.ReadChannel(i, out pwmhigh[i-1], out pwmlow[i-1]);
var millis3 = milliend - millistart; // Here I get something between 300 and 400msecs
Don’t use event, it can be 3x faster.
But the driver is in C# code, use I2C - daisy link, we cannot expect it is fast like the firmware in native code.
Many thanks Dat, so my only “error” on this one was to use the Timer? I’ll make sure to test this asap, but from your post, it sure looks like that would be the cause. 90msecs, like you got, would be quite enough for my requirements, so I don’t think I have to tinker around with native code here. Just one more question… Should I decide to pick up another PulseInOutModule (I do need 16 PWM in and out) and daisy link it to this one, can I still expect the same performance?
Also many thanks for pointing me to the right thread with the IO60p16, I seemingly was too blind to find it myself
Thanks, please do. I don’t have a problem with shopping another board, as long as I can be certain that it works
Alternatively, just to be sure that there’s nothing weird inbetween, you might send me your code so I can try that 1:1 on my hydra. But I suppose you have more hardware ressources on your side anyway
