I was told not to tell you this so I am not!! Joe got TCP server going. Out of everything (TCP client and UDP…etc.), this is the most difficult to handle so from this point on, things will move very quickly
Get your Ethernet shield and Ethernet cables ready…we will have something very very soon 8)
So, does FEZ Panda (the freakin’ small board) support Ethernet? Yes it does…what about SD cards…yes it does…what makes FEZ Panda limited? Nothing! It is the best thing that ever happened to hobbyists and will really change the projects from xxxduino-blink-LED to something amazing…my personal opinion but I am pretty sure I will have a lot who will agree.
Man, I can’t wait to see those production Pandas :wall:
It only misses the RJ45 connector onboard, unlike its RS232 sister But the small size is still an advantage, I think. The RJ45 connector can be placed elsewhere, “far” from the board if I want.
We will give you support with standard .NET socket that is officially and commercially supported by GHI…oh, and you get that for free! Nothing beats that
tutorials+examples… everything will be freakin’ easy…this is FEZ!
Since this is standard .NET sockets than you can almost take any .NET sockets example and it will work on FEZ so you have already 1000 tutorials on the web
@ Chris: The driver uses the reset pin so it is a straight forward thing with FEZ Rhino.
But for arduino Ethernet Shield?! Maybe some hardware hacking has to be done to connect the rest pin to one of the GPIOs.
But The chip itself has a software reset. so this might be a solution for this shield. We will do some tests and get back with a solution for sure.
