In the case of the board that Pete Brown made for me, I’m using a combination of 4-40 bolts (various lengths) and nuts, some aluminum stand-offs (hex-style, male on one end and female on the other, also 4-40), and plastic through-threaded standoffs. Most of the parts I got either at Sparkfun, or at my local home improvement store (unfortunately, only one of the local places carries bolts as small as 4-40).
I’m sure you could easily use the hardware that comes with these mounting plates, though with only 18 nuts and bolts, you’d probably need more to mount all your modules, and since many of the modules do need some kind of stand-off, you’d probably need some longer nuts & bolts in addition to what comes with the universal plate.
Still, it looks like a very promising solution for mounting Gadgeteer gear. And the fact that you can get them in different sizes, and combine them in interesting ways is also very useful. Will be ordering some of these soon.
I did the same as @ devhammer - 4-40 bolts and spacers. The board does come with bolts and nuts, but they’re very short and don’t work for attaching the modules. The 4-40 bolts and spacers are very easy to get hold of. If you’re in the UK then you can get the board and the bolts from Proto-PIC (which is where I got all mine from).
In the photo with the prototype board you borrowed from the Gadgeteer team, I see some snap-in nylon stand-offs…do you have a source for ordering those? They look REALLY useful for prototyping, especially compared to nuts/bolts.
I don’t have a solid plan yet, but yes, I want to build a robot. Right now, I’m just starting to fill in some of the holes in my parts supply, so I’ll have plenty of what I need on hand.
In addition to the parts in the list above, I have a LEGO Mindstorms kit that I am going to look into integrating. If I can use those motors and parts, it’ll lend a ton of flexibility in terms of adding arms, grabbers, etc.
No, I don’t think it’ll be hard at all. Just a matter of figuring out which wires do what, and though I haven’t searched yet, I’m betting that info is available somewhere online. If not, I can always test my way to finding it. Sometimes, discovery is half the fun.
Yes, it uses something similar to a phone jack, though it’s not (AFAICT) an RJ-11 or RJ-45.
That’s actually a really great idea for a module…combine a motor controller with a port for the LEGO motor cable, and you wouldn’t need to hack the cable up to connect it. Nice!
