Version 1.1 online.
Main differences:
- Added Hydra
- Adapted to GHI SDK 4.3.4
- Added section explaining multiple RLP image loading
- First paragraphs about RLP extensions.
- added and revised examples and templates
Version 1.1 online.
Main differences:
Excellent, thanks
Thank you Simon!
@ Simon from Vilnius - I recon that the cerberus template can be used for the first generation cerb40s as well.
I just managed to revive two cerb40 from having no FW to the latest (4.3.4 and 4.3.6) after updating the HW to 20 pin dil and rtc stuff and I am about to experiment a bit with RLP …
BTW, how the hell can the GPIO (PBx preferably) directly be addressed in RLP ?
Looking at the data sheet it gives me only some AHB1 and f.e. GPIOB at addr 0x4002 0400 but I only need to address the output bits, having only 16 of them shouldn’t take 1024 address spaces or ?
Any pointers to example, refs, dox, I’m from the 80s, stopped with PIAs and VIAs so I guess things have evolved a bit since than … and I am probably taking things to easy by assuming that I [em]‘only’[/em] need to set the output bits …
Basic question how do I set a couple of outputs (to ‘0’ or ‘1’) by anding the full 16 bits (or more or less) and masking the maybe used bits by doing:
PBIO &= some_ hexvalue_masking_the_used_bits;
As far as I can see on Cerb I need to mask out bits 2, 6 - 11, 14 and 15 (LSB->MSB) if I want to use the BP bits on the Cerbuino headers.
And this of course in RLP not in C# …
Thanks anyway for your time …
Noob question: Where?
Edit: Durr. Nevermind. It helps to read the full thread.
Edit #2:
That was a fantastically useful (and entertaining) document. I am finally excited about RLP. Thanks for your work!
You’ve got two options.
Since Cerberus has full RLP support, you can use extensions. Check RLP.h file, it has a bunch of methods for controlling pins (“Writepin”, “Readpin” and others). Dig Codeshare for actual usage examples, I definitely saw some.
You can use bare metal features. Check stm32F4xx.h file, it has all the definitions. What particularly interests you, is:
typedef struct {
__IO uint32_t MODER; /*!< GPIO port mode register, Address offset: 0x00 */
__IO uint32_t OTYPER; /*!< GPIO port output type register, Address offset: 0x04 */
__IO uint32_t OSPEEDR; /*!< GPIO port output speed register, Address offset: 0x08 */
__IO uint32_t PUPDR; /*!< GPIO port pull-up/pull-down register, Address offset: 0x0C */
__IO uint32_t IDR; /*!< GPIO port input data register, Address offset: 0x10 */
__IO uint32_t ODR; /*!< GPIO port output data register, Address offset: 0x14 */
__IO uint16_t BSRRL; /*!< GPIO port bit set/reset low register, Address offset: 0x18 */
__IO uint16_t BSRRH; /*!< GPIO port bit set/reset high register, Address offset: 0x1A */
__IO uint32_t LCKR; /*!< GPIO port configuration lock register, Address offset: 0x1C */
__IO uint32_t AFR[2]; /*!< GPIO alternate function registers, Address offset: 0x20-0x24 */
} GPIO_TypeDef;
So setting a pin would look something like GPIOA->ODR |= (1<<[em]yourPinNumberHere[/em]). It seems that everybody manipulates whole ports, not individual pins these days, but does that really matter?
@ Simon from Vilnius - Thanks for the tips, I’ll try and have a go
I’d rather set the whole register with the bits in ONE and operation than do a rotation over left multiple times. I reckon that the 8X ROL operation takes more cycles than 1x AND operation. That, would be a waste of cycles. Plus the fact that I have to blend out (mask) certain bits and as far as I know the ROL inserts a ‘0’ after the action. Way back in time we ought to have a distinction between rolling and shifting bits.
Have to set the bits as accordingly in the attached picture. Where X is/are the bit(s) that I’d like to set.
Excuse me my ignorance but how many bits are the registers ? 32 ?
Is the MSB shifted to a carry bit or overflow bit somewhere or just gone forever ?
Can a piece of code (C/C++) from some ARM taken to another ARM MCU, with corrections on probably the I/O, timers and ?
Ah, probably too many noob questions, any recommendations on a good read on the ARM / STM stuff ?
Or is someone planning on a kind of workshop with a focus on RLP ? (Germany would be fine, or not too far from).
That must be some really ancient stuff as I have [em]no [/em]idea what are you talking about
To set pins:
GPIOB->ODR|=(1<<0)|(1<<1)|(1<<3)|(1<<4)|(1<<5)|(1<<12)|(1<<13);
The clear the same pins:
GPIOB->ODR&=~((1<<0)|(1<<1)|(1<<3)|(1<<4)|(1<<5)|(1<<12)|(1<<13));
Yes, but some bits may be reserved — check the manual…
No shifting happens here.
No problems with core stuff, but peripherals will probably need porting…
