HTTP Server using Dynamic Html Pages
This project deals with using an Http server that enable interacting with the user, by providing several input fields type such as checkbox, input, button…
The purpose is to provide a logic that is near from the way of developing with ASP.
=> an html file containing the fields view and javascript for presentation,
=> a codebehind file that make all the stuf around the get and put of the html page rendering,
=> some abstract classes that will facilitate the adding of other pages, by providing standard methods to be replicated to your needs…
In this sample, I added an IPConfiguration logic that will enable the user to retrieve and apply the device IP configuration directly by the embedded HTTP server, without the need to use MF Deploy or hardcode anything on the program level !
I personally use a G120HDR with an ENC28, but it will be very easy to port to another board and PHY as well…
