The new G400HDR Gadgeteer Mainboard driver is now available. It supports SDK version 4.2.11.0 with Gadgeteer Core 2.43.800.0.
The installation project has also been updated to support WiX version 3.7
I have updated the G400D Mainboard driver to support the latest GHI Firmware (NETMF and Gadgeteer Package 2013 R3)
Find it on codeshare:
https://www.ghielectronics.com/community/codeshare/entry/739
Has anyone played around with this using the RGB sockets for GPIO?
I had an incident with my Cerberus yesterday, may he rest in peace. So I swapped out the Cerb for the G400, being that theyāre such similar devices, and that Iāve hardly ever used my G400. In my code I allocate a socket for my own IO use, I have 3 buttons and a relay that I trigger from it.
MultiIO = GT.Socket.GetSocket(1, true, null, "Multi");
btn1_Engage_Rly = new InputPort(MultiIO.ReservePin(Gadgeteer.Socket.Pin.Three, null), true, Port.ResistorMode.PullUp);
All works as expected on compilation. On deployment however, none of my button presses were working !
So I play around a little⦠by moving my breakout connector I can see that what is physically marked āSocket 3ā reacts when I use the above code for Socket 1 and vice-versa.
I canāt remember seeing anything that talked about the silkscreen being wrong, but this did come from the beta pool of devices, so I assume that Iāve just missed something.
Thanks again to Taylorza as this made swapping in the device a breeze into my Gadgeteer project.
@ Brett - I have confirmed the issue and reviewed the pin mappings. It seems that the socket 1 and 3 are mapped in reverse. I will fix it now and test it, but I need to test both with and without a display. I will post here as soon as the fix is up, hopefully the next 15-20 min.
The strange thing is that I tested those sockets with a display originally, and would have expected the colors to be incorrect if they where mapped incorrectly. I must have missed somethingā¦
@ Brett - I have uploaded a new version of the mainboard driver with the correction for socket 1 and 3. Please let me know if you have any other issues.
Mate, love your work. This now works as youād expect, socket 1 is socket 1.
@ Brett - Thank you for the complement and thanks for reporting the issue so that I had the opportunity to take a look and improve the mainboard driver.
