@ MikeCormier
Excuse me to disturbe you.
I use the G120HDR mainboard with a WifiRS21 module and a USB DP module with success with MF4.2 but I want to migrate to MF4.3 and I have some problem.
Your G120HDR project is not compilated with the current MF 4.3 version.
On my computer, the DLL of the Microframework 4.3 are in version 4.3.1.0 and your G120HDR need version 4.3.0.0.
When I launch the debug I have the following error:
Found debugger!
Create TS.
Loading start at a0e68e2c, end a0e982c0
Assembly: mscorlib (4.3.1.0) Assembly: Microsoft.SPOT.Native (4.3.1.0) Assembly: Microsoft.SPOT.Security.PKCS11 (4.3
.1.0) Assembly: System.Security (4.3.1.0) Assembly: Microsoft.SPOT.Hardware (4.3.1.0)
Assembly: Microsoft.SPOT.Graphics (4.3.1.0) Assembly: Microsoft.SPOT.TinyCore (4.3.1.0)
Assembly: Microsoft.SPOT.IO (4.3.1.0) Assembly: System.IO (4.3.1.0) Assembly: Microsoft.SPOT.Hardware.Usb (4.3.1.0)
Assembly: Microsoft.SPOT.Hardware.SerialPort (4.3.1.0) Assembly: Microsoft.SPOT.Touch (4.3.1.0)
Assembly: Microsoft.SPOT.Ink (4.3.1.0) Assembly: Microsoft.SPOT.Hardware.PWM (4.3.1.0)
Attaching deployed file.
Assembly: Gadgeteer (2.43.1.0) Attaching deployed file.
Assembly: Gadgeteer.WebClient (2.43.1.0) Attaching deployed file.
Assembly: GHI.Hardware (4.3.6.0) Attaching deployed file.
Assembly: Gadgeteer.WebServer (2.43.1.0) Attaching deployed file.
Assembly: System.Http (4.3.1.0) Attaching deployed file.
Assembly: Gadgeteer.SPI (2.43.1.0) Attaching deployed file.
Assembly: System (4.3.1.0) Attaching deployed file.
Assembly: Microsoft.SPOT.Net (4.3.1.0) Attaching deployed file.
Assembly: GTM.GHIElectronics.USBClientDP (4.3.6.0) Attaching deployed file.
Assembly: Gadgeteer.DaisyLink (2.43.1.0) Attaching deployed file.
Assembly: GTM.GHIElectronics.WiFiRS21 (4.3.6.0) Attaching deployed file.
Assembly: System.Net.Security (4.3.1.0) Attaching deployed file.
Assembly: KapitenG120MF43 (1.0.0.0) Attaching deployed file.
Assembly: Microsoft.SPOT.Net.Security (4.3.1.0) Attaching deployed file.
Assembly: MCORMIER.Gadgeteer.G120HDR (1.0.0.0) Attaching deployed file.
Assembly: GHI.Networking (4.3.6.0) Resolving.
Assembly: KapitenG120MF43 (1.0.0.0) needs assembly âMCORMIER.Gadgeteer.G120HDRâ (1.0.0.0)
Assembly: MCORMIER.Gadgeteer.G120HDR (1.0.0.0) needs assembly âMicrosoft.SPOT.Hardwareâ (4.3.0.0)
Assembly: MCORMIER.Gadgeteer.G120HDR (1.0.0.0) needs assembly âMicrosoft.SPOT.Graphicsâ (4.3.0.0)
Assembly: MCORMIER.Gadgeteer.G120HDR (1.0.0.0) needs assembly âmscorlibâ (4.3.0.0)
Assembly: MCORMIER.Gadgeteer.G120HDR (1.0.0.0) needs assembly âMicrosoft.SPOT.Nativeâ (4.3.0.0)
Error: a3000000
Waiting for debug commandsâŠ
Le programme â[1] Micro Framework application: ManagĂ©â sâest arrĂȘtĂ© avec le code 0 (0x0).
I have recompilated your program on my computer with success but there is a warning âAvertissement 2 Le projet ââŠ\G120HDR_43\G120HDR_43.csprojâ ne peut pas ĂȘtre rĂ©fĂ©rencĂ©. Le projet rĂ©fĂ©rencĂ© cible une famille de framework diffĂ©rente (.NETMicroFramework) G120HDRâ
Translated in english is like this: The projet âG120HDR_43.csprojâ cannot be referenced because it target a different familly of framework.
I have uninstalled your G120HDR driver and installed mine driver.
Now I can launch the debug, I have not link error but this error message:
Une exception non gĂ©rĂ©e du type âGadgeteer.Socket.PinMissingExceptionâ sâest produite dans Gadgeteer.dll
Informations supplémentaires :
Pin 3 on socket 5 is not connected to a valid CPU pin.
Complete trace:
Found debugger!
Create TS.
GC: 1msec 488376 bytes used, 6851292 bytes available
Type 0F (STRING ): 24 bytes
Type 15 (FREEBLOCK ): 6851292 bytes
Type 17 (ASSEMBLY ): 39396 bytes
Type 1E (BINARY_BLOB_HEAD ): 448884 bytes
GC: performing heap compactionâŠ
Ready.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (ManagĂ©) : âC:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\mscorlib.dllâ chargĂ©, symboles chargĂ©s.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (ManagĂ©) : âC:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Native.dllâ chargĂ©, symboles chargĂ©s.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (ManagĂ©) : âC:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.dllâ chargĂ©, symboles chargĂ©s.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (ManagĂ©) : âC:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Security.PKCS11.dllâ chargĂ©, symboles chargĂ©s.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (ManagĂ©) : âC:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\System.Security.dllâ chargĂ©, symboles chargĂ©s.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (ManagĂ©) : âC:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Graphics.dllâ chargĂ©, symboles chargĂ©s.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (ManagĂ©) : âC:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.TinyCore.dllâ chargĂ©, symboles chargĂ©s.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (ManagĂ©) : âC:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.IO.dllâ chargĂ©, symboles chargĂ©s.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (ManagĂ©) : âC:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\System.IO.dllâ chargĂ©, symboles chargĂ©s.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (ManagĂ©) : âC:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.Usb.dllâ chargĂ©, symboles chargĂ©s.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (ManagĂ©) : âC:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.SerialPort.dllâ chargĂ©, symboles chargĂ©s.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (ManagĂ©) : âC:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Touch.dllâ chargĂ©, symboles chargĂ©s.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (ManagĂ©) : âC:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Ink.dllâ chargĂ©, symboles chargĂ©s.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (ManagĂ©) : âC:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.PWM.dllâ chargĂ©, symboles chargĂ©s.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (ManagĂ©) : âC:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Net.dllâ chargĂ©, symboles chargĂ©s.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (ManagĂ©) : âC:\Program Files (x86)\Microsoft .NET Gadgeteer\Core\Assemblies.NET Micro Framework 4.3\le\Gadgeteer.dllâ chargĂ©, symboles chargĂ©s.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (ManagĂ©) : âC:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\System.dllâ chargĂ©, symboles chargĂ©s.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (ManagĂ©) : âC:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Net.Security.dllâ chargĂ©, symboles chargĂ©s.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (ManagĂ©) : âC:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\System.Net.Security.dllâ chargĂ©, symboles chargĂ©s.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (ManagĂ©) : âC:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\System.Http.dllâ chargĂ©, symboles chargĂ©s.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (ManagĂ©) : âC:\Program Files (x86)\Microsoft .NET Gadgeteer\Core\Assemblies.NET Micro Framework 4.3\le\Gadgeteer.WebClient.dllâ chargĂ©, symboles chargĂ©s.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (ManagĂ©) : âC:\Program Files (x86)\GHI Electronics\GHI NETMF v4.3 SDK\Libraries\le\GHI.Hardware.dllâ chargĂ©
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (ManagĂ©) : âC:\Program Files (x86)\Microsoft .NET Gadgeteer\Core\Assemblies.NET Micro Framework 4.3\le\Gadgeteer.WebServer.dllâ chargĂ©, symboles chargĂ©s.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (ManagĂ©) : âC:\Program Files (x86)\Microsoft .NET Gadgeteer\Core\Assemblies.NET Micro Framework 4.3\le\Gadgeteer.SPI.dllâ chargĂ©, symboles chargĂ©s.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (ManagĂ©) : âC:\Program Files (x86)\GHI Electronics\GHI .NET Gadgeteer SDK\Modules\USBClientDP\NETMF 4.3\le\GTM.GHIElectronics.USBClientDP.dllâ chargĂ©, symboles chargĂ©s.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (ManagĂ©) : âC:\Program Files (x86)\Microsoft .NET Gadgeteer\Core\Assemblies.NET Micro Framework 4.3\le\Gadgeteer.DaisyLink.dllâ chargĂ©, symboles chargĂ©s.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (ManagĂ©) : âC:\Program Files (x86)\GHI Electronics\GHI NETMF v4.3 SDK\Libraries\le\GHI.Networking.dllâ chargĂ©
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (ManagĂ©) : âC:\Program Files (x86)\GHI Electronics\GHI .NET Gadgeteer SDK\Modules\WiFiRS21\NETMF 4.3\le\GTM.GHIElectronics.WiFiRS21.dllâ chargĂ©, symboles chargĂ©s.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (ManagĂ©) : âC:\Program Files (x86)\GHI Electronics\Microsoft .NET Gadgeteer\Mainboards\G120HDR\NETMF 4.3\le\MCORMIER.Gadgeteer.G120HDR.dllâ chargĂ©, symboles chargĂ©s.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (ManagĂ©) : âC:\Users\OCBO5422\Documents\Visual Studio 2012\Projects\Microframework_4.3\KapitenG120\KapitenG120MF43\KapitenG120MF43\bin\Debug\le\KapitenG120MF43.exeâ chargĂ©, symboles chargĂ©s.
Le thread ââ (0x2) sâest arrĂȘtĂ© avec le code 0 (0x0).
Warning: socket 5 is not compliant with Gadgeteer : Cpu pin 3 must be specified for socket of type D
Warning: socket 5 is not compliant with Gadgeteer : Cpu pin 6 must be specified for socket of type D
Warning: socket 5 is not compliant with Gadgeteer : Cpu pin 7 must be specified for socket of type D
Using mainboard MCormier G120HDR version 1.0
#### Exception Gadgeteer.Socket+PinMissingException - 0x00000000 (1) ####
#### Message:
#### Gadgeteer.Socket::ReservePin [IP: 0019] ####
#### Gadgeteer.Modules.GHIElectronics.USBClientDP::.ctor [IP: 0019] ####
#### KapitenG120MF43.Program::InitializeModules [IP: 000e] ####
Une exception de premiĂšre chance de type âGadgeteer.Socket.PinMissingExceptionâ sâest produite dans Gadgeteer.dll
WARN: Total initialization time exceeds 10 seconds.
: ProgramStarted is blocking execution, which means events and timers will not run properly.
: Make sure not to use blocking code such as while(true) - use a GT.Timer instead.
Uncaught exception
Le thread ââ (0x1) sâest arrĂȘtĂ© avec le code 0 (0x0).
