Cerberus DL40 Programmer
The code to flash the DL40 currently uses the Gadgeteer framework which while very convenient makes it difficult to use the Cerberus family of boards to flash a DL40 due to the limited remaining memory.
As an experiment prompted by a post on the TinyCLR forum, I decided to see if changing the project to a pure .NETMF project I would have any success and I am happy to report that it went swimmingly.
I thought might be useful to someone out there that wants to work with the DL40 but only has a Cerberus. So here is the code including the default DL40 firmware.
Setup:
Cerberus Main board
Socket 7 : Button module
Socket 6 : DL40 (Connect to the * end for programming)
All messages, instructions and flash progress is shown in the “Debug Output Window” so it is easiest to run the application under the debugger.
See http://wiki.tinyclr.com/index.php?title=OpenDaisyLink for more details on the DL40 and the Open DaisyLink initiative from GHI.
