Hello, I’m new
I recently bought a Fez Hydra and Motor Driver L298 Module. Today I faced a problem. I connected the module to the battery and the motor (photo in attachment) and wrote a simple program:
Have you tried using MotorControllerL298.Motor.Motor2? I have this module and have had it connected exactly like you have and it worked. I am not able to check the code now so I cannot confirm which Motor constant I used, maybe it is worth trying if you have not already tried.
Do the LEDs on the module come on? Also have you tried a value less than 100, the driver actually has some explicit code to handle the case when 100 is passed so maybe you could try something like 80 to see if there is any difference.
