on G400? If we did not confirm the report or not showing here https://www.ghielectronics.com/docs/227/post-release-issues then we missed it. Please report it again or call/email us with the issue so we can look into it. We must have missed it?
I also really hope G400 can work as replacement for the ChipworkX module really soon, because we are in the exact same situation as you Dave (having custom hardware products based on ChipworkX with potential orders coming in quite soon).
Since this is my first topic in here, I of course also have a stupid question - do I accept Gusā answer of reporting it to the team as a solution? Or should I āleave it openā until the issue is actually resolved?
I hope this can be fixed. Getting hold of 2GB cards around here is near on impossible now and the stock I had from a few months ago is empty. The smallest I can find now is 4GB. There are 2GB cards sold here but I have had so many issues with that make, I only purchase Sandisk now for commercial use.
Iām just about to list a few 1Gb ones on ebay, but theyāll be expensive, do you want me to post the link once Iāve done it ?
(no Iām not, but I thought I should say that).
And I suspect now the bug has been identified itās on the radar to be addressed - John will let us know if we need to lobby Gus, or to up-vote something on codeplex right
@ John - I just tried with a 1GB Micro SD with adapter and unfortunately with the same result as before: IOException - CLR_E_INVALID_DRIVER.
So unless it doesnāt support Micro SD cards, the bug with larger SD cards, seems to unfortunately not be the problem here.
Which cards are you guys at GHI testing with to get this to work (manufacturer, size and type)?
In the current firmware, you must use SD as root for device in paths, SD_SPI is only used in constructing the PersistentStorage object. In the coming SDK that is corrected so that SD_SPI is the root used in paths. As for the size limitation, any sized media will work, but those with a size over 4GB will be capped at 4GB in reported size. Operations such as reading, writing, and formatting work properly and can use the entire size.
@ John - Thatās very good news, thanks John! I have tested your solution with my 1GB micro sd card now, and using SD instead of SD_SPI after the mount, works perfectly.
