We have hit a bit of a brick wall getting a Fez Hydra mainboard up and running on a Windows 7 64bit machine, running C# express 2010.
We have installed Visual C# Express 2010, and although the NETMF and Gadgeteer Package 2014 R2 itself failed, we did manage to install all its components, namely, MicroFrameworkSDK 4.2, GadgeteerCore, sam-ba2.12 and DfuSe_Demo_V3.0.3_Setup_amd64. (we also tried the x86 version of the latter, which failed, presumably because the 64bit version was already installed).
The result is that we get as far as the āChoose a mainboardā dialog. This window is empty and a warning is displayed, āNo mainboards were found on this system. Please install a SDK from the manufacturer of your mainboard.ā
We have searched widely for other SDKs for the Fez Hydra without luck. What are we doing wrong?
Ah yes, I omitted to say we have tried with both configurations: Visual C# Express 2010 with MicroFrameworkSDK 4.2, and Visual C# Express 2012 with MicroFrameworkSDK 4.3. We get exactly the same behaviour both ways.
@ royshearer - I would uninstall everything related to NETMF, Gadgeteer, and our SDK. Make sure that any NETMF SDK is uninstalled and that VS2012 is installed. Then run our 2014 R2 installer and see if the mainboards appear.
Next question: On p17 I am asked to select JoystickPressed from the IntelliSense menu. I am not offered this however. I am offered some other options shown in the attached screenshot instead.
Which should I choose, or does this indicate there being something wrong with my software installation?
If you look closely at the example, you see that the object you want is ājoystickā with a lower case j. This is the name of your object. Your code is currently written with an uppercase J - this is the name of the Joystick class. Use the object joystick and you should see the methods that you are looking for.
using System.Collections;
using Microsoft.SPOT.Touch;
using Gadgeteer.Networking;
using GT = Gadgeteer;
namespace GadgeteerApp5
public partial class Program
timer.Tick +=<tab><tab>
timer.Start();
joystick.JoystickPressed += joystick_JoystickPressed;
joystick.JoystickReleased += joystick_JoystickReleased;
void joystick_JoystickReleased(Joystick sender, Joystick.JoystickState state)
Debug.Print("Joystick Released");
led7R.TurnLightOn(7, true);
void joystick_JoystickPressed(Joystick sender, Joystick.JoystickState state)
Debug.Print("Joystick Pressed");
led7R.TurnLightOff(7);
For some reason my software prefers
to [code=cs]ālED7Rā[/code
My Hydra and modules are connected as instructed. When I choose āStart Debuggingā I get:
Looking for a device on transport 'USBā
Starting device deploymentā¦
Iteration 0
And it continues slowly counting through iterations, ultimately stopping, without any behaviour change from the Hydra and modules. Is this what I should I expect to happen? Could there be a problem with my connections?
I still canāt seem to get beyond this point, text from the output window:
Looking for a device on transport āUSBā
Iteration 0
Opening port \?\usb#vid_1b9f&pid_0102#0000000001#{d32d1d64-963d-463e-874a-8ec8c8082cbf}
Attaching debugger engineā¦
ā¦ cannot attach debugger engine!
āThere were deployment errors. Continue?ā dialogue, I click Yes.
āAn exception occurred while attempting to launch the debugger: Object reference not set to an instance of an object.ā dialogue, I click OK.
The operation could not be completed.ā dialogue, I click OK.
In the Error list I get this:
Warning 1 Cannot find a schema that defines target namespace āhttp://schemas.microsoft.com/dsltools/GadgeteerDSLā, schema validation skipped. C:\Users\r.shearer\Documents\Visual Studio 2012\Projects\GadgeteerApp5\GadgeteerApp5\Program.gadgeteer 2 2 GadgeteerApp5
Warning 2 Cannot find a schema that defines target namespace āhttp://schemas.microsoft.com/dsltools/GadgeteerDSLā, schema validation skipped. C:\Users\r.shearer\Documents\Visual Studio 2012\Projects\GadgeteerApp5\GadgeteerApp5\Program.gadgeteer.diagram 2 2 GadgeteerApp5
Error 3 Unable to communicate with device USB:Gadgeteer
I have tried pinging the board in FEZ Config and I get this:
Device not found or cannot be opened - USB:Gadgeteer
Pingingā¦
Failure - Device is not connected or not responding.
Too me, it looks like you should try a new vs project and start with a simple design with only a button. The current vs project might be in a bad state.
Hi Jeff, thanks for that. I have followed the steps in āLoader updateā at the link you posted above. I hit a snag on the last step however in that the board still does not show up in Fez Config. I have tried opening Fez Config when the board is in 3 different states: the serial connection mode that I used to update the Loader; the same but having reset the board; and connecting in the normal USB mode.
Basically, there still seems to be a fundamental problem with the board connection. The board used to show up intermittently in Fez config and now it never shows up at all.
