Hey, iv connected a Mouse and wrote a program that draws on my LCD.
Everything works fine, the only problem is that the mouse moves easy in -x and -y directions but i need to move the Mouse fast and much more far to move the cursor in +x and +y positions.
Does anyone have an idea what the problem could be?
Okey, i did that but it doesn’t change anything,
the cursor moves with normal mouse movements in - Positions (left and up) but i need a fast mouse movement to move it in + positions (right and down)
I tried a different mouse aswell, but its still the same problem
Slow Movements to the right and down are not doing anything… i need to move the mouse fast.
Sounds like a bug to me. But you can work around it ( I think).
Try adjusting the Cursor yourself based on the information in DeltaPosition of the USBH_MouseEventArgs inside your move handler.
@ Gus: That just moves it quicker, but just in -x direktions,
the problem is that i need to move the mouse fast in +x/y directions so a move is detected at all.
@ andre.m: RLP, i think that’s a bit to hard for me at this time, and changing a driver… :D,
just got my spider yesterday, and i’m complete new to this.
[quote]
Each connected Mouse holds information about the current pressed buttons and the current position.
Position
The position can be obtained as a Delta Position (Relative) in an event or as a Cursor associated with it (Absolute). The default Delta Position changes from -512 to +512. This can be changed by calling Scale().
For Cursor position, by default, is from 0 to 512 for X and Y. This can be changed as well. Changing the scale for certain cursor bounds will have the affect of changing cursor speed.
Events
Dela position of the mouse or the state of the buttons are sent as events to the user.
For this device, there is an internal thread that maintains the device events. The thread priority is set to the highest settings but the user is able to change this thread priority to optimize the program performance. [/quote]
I wonder if by changing the bounds you have affected the speed since the scale is not changed.
Edit: Try not changing the bounds and see if speed issue is still there
@ Gus: yes i did on both lines, still doesn’t help.
it seems to me that the mouse move event it not called when i don’t move the mouse quickly to right or down.
It is however, no matter how slow i move the mouse to the left or up.
@ Architect: even when i don’t set the bounds, its still the same issue.
Looks like the USB drivers is not polling the mouse fast enough. We will look into this but to be honest this is a low priority items when compared to other tasks we have now.
