Hi to all,
we develop on Hydra board with GPS module and we used a plublic gps driver (downloaded from http://gadgeteer.codeplex.com).
We write some codes and the module works, but the gps position is always “$GPRMC,V,N*53”.
We move gps module outside the house with clear sky but nothing.
We try to using the car to move the modulo around the house but nothing.
Is there something wrong?
We are alone with this problem?
You’ll need to be more specific to get any meaningful answers… What GPS? What driver on the gadgeteer site? Reading serial data is fairly trivial. It sounds like you need to some kind of initialization to configure the GPS on startup? The configuration specifics are usually manufacturer dependent.
in the driver, on constructor, the code are the follow
Socket socket = Socket.GetSocket(socketNumber, true, this, null);
powerControl = new GTI.DigitalOutput(socket, Socket.Pin.Three, true, this);
gpsExtInt = new GTI.DigitalOutput(socket, Socket.Pin.Six, true, this);
serial = new GTI.Serial(socket, 9600, GTI.Serial.SerialParity.None, GTI.Serial.SerialStopBits.One, 8, GTI.Serial.HardwareFlowControl.NotRequired, this);
serial.AutoReadLineEnabled = true;
serial.LineReceivedEventDelimiter = "\r\n";
serial.LineReceived += new GTI.Serial.LineReceivedEventHandler(serial_LineReceived);
form the serial buffer we received other strings, but now I dont have. In this evening I will post more details.
We attach the module on port number 7.
So which event receives the ‘empty’ NMEA string? If you’re getting something back from the provided driver, then the place to look is the GPS itself. Your best bet is to contact the manufacturer of the GPS and/or get a user manual or datasheet for it. You can use this to verify that Seeed’s driver is doing what it should to initialize the GPS.
In general, the drivers Seed has provided to date are buggy, so while it sucks that this module is not ‘plug and play’, it is not surprising. I see you have responded to other posts about this hardware. I did not find any that indicated anybody here has actually has the GPS working.
@ devhammer has one, but I’m not sure if he has it working yet (based on another thread). Also, maybe GHI can test this module and provide some super simple demo code. Guys?
Hi, I would add more information.
This is the last logs:
GPS : $GPRMC,V,N53
GPS : $GPVTG,N30
GPS : $GPGGA,0,00,99.99,48
GPS : $GPGSA,A,1,99.99,99.99,99.9930
GPS : $GPGSV,1,1,0079
GPS : $GPGLL,V,N64
For test I change socket number from 7 to 4, but nothing
to me this says the GPS isn’t locking on. The problem is more likely electrical interference or not giving the unit a long time (maybe 30 mins!) for first cold lock. How long did you sit it in the open sky for? What aerial wiring and placement relative to main electronics do you use?
yes I powered module for more than 5 minutes. Yesterday I leave the module outside for more than 1 hours, but no satellite find.
I try to find the documentation to undestand if the driver or something else is wrong, but I find only NEO6 schema documentation, but not a integration schema to check a connection and pin…
Have you contacted Seeed directly about your issue? I would suggest asking for a refund or replacement if you cannot resolve the problem through usual support channels.
