Remove and add GHI references?
I have removed GHI references and added GHI references again. but it is giving same problem.
Please find the output file as under.
[line]
[title]Output file[/title]
Rebooting…
Create TS.
Loading start at a0200000, end a0209b4c
Attaching file.
Assembly: mscorlib (4.1.2821.0) (3880 RAM - 33236 ROM - 19134 METADATA)
AssemblyRef = 0 bytes ( 0 elements)
TypeRef = 0 bytes ( 0 elements)
FieldRef = 0 bytes ( 0 elements)
MethodRef = 0 bytes ( 0 elements)
TypeDef = 1112 bytes ( 139 elements)
FieldDef = 272 bytes ( 135 elements)
MethodDef = 1572 bytes ( 786 elements)
Attributes = 0 bytes ( 0 elements)
TypeSpec = 16 bytes ( 4 elements)
Resources = 232 bytes ( 29 elements)
Resources Files = 16 bytes ( 2 elements)
Resources Data = 437 bytes
Strings = 1551 bytes
Signatures = 2126 bytes
ByteCode = 11702 bytes
Attaching file.
Assembly: Microsoft.SPOT.Native (4.1.2821.0) (1144 RAM - 6516 ROM - 4479 METADATA)
AssemblyRef = 4 bytes ( 1 elements)
TypeRef = 80 bytes ( 20 elements)
MethodRef = 60 bytes ( 15 elements)
TypeDef = 336 bytes ( 42 elements)
FieldDef = 192 bytes ( 95 elements)
MethodDef = 224 bytes ( 111 elements)
Attributes = 48 bytes ( 6 elements)
TypeSpec = 0 bytes ( 0 elements)
Resources = 72 bytes ( 9 elements)
Resources Files = 8 bytes ( 1 elements)
Resources Data = 747 bytes
Strings = 648 bytes
Signatures = 595 bytes
ByteCode = 418 bytes
Attaching deployed file.
Assembly: Microsoft.SPOT.Graphics (4.1.2821.0) (388 RAM - 2268 ROM - 1357 METADATA)
AssemblyRef = 8 bytes ( 2 elements)
TypeRef = 24 bytes ( 6 elements)
MethodRef = 20 bytes ( 5 elements)
TypeDef = 40 bytes ( 5 elements)
FieldDef = 16 bytes ( 8 elements)
MethodDef = 96 bytes ( 48 elements)
Resources = 0 bytes ( 0 elements)
Resources Files = 0 bytes ( 0 elements)
Resources Data = 0 bytes
Strings = 537 bytes
Signatures = 293 bytes
ByteCode = 242 bytes
Assembly: Project_Sample_2 (1.0.0.0) (812 RAM - 6076 ROM - 2146 METADATA)
AssemblyRef = 28 bytes ( 7 elements)
TypeRef = 216 bytes ( 54 elements)
FieldRef = 8 bytes ( 2 elements)
MethodRef = 244 bytes ( 61 elements)
TypeDef = 56 bytes ( 7 elements)
FieldDef = 68 bytes ( 33 elements)
MethodDef = 36 bytes ( 18 elements)
Resources = 24 bytes ( 3 elements)
Resources Data = 1052 bytes
Strings = 1443 bytes
Signatures = 406 bytes
ByteCode = 1259 bytes
Assembly: GHIElectronics.NETMF.System (4.1.3.0) (440 RAM - 2220 ROM - 1281 METADATA)
AssemblyRef = 12 bytes ( 3 elements)
TypeRef = 36 bytes ( 9 elements)
MethodRef = 48 bytes ( 12 elements)
TypeDef = 72 bytes ( 9 elements)
FieldDef = 28 bytes ( 13 elements)
MethodDef = 72 bytes ( 36 elements)
Strings = 496 bytes
Signatures = 181 bytes
ByteCode = 314 bytes
Invalid native checksum: GHIElectronics.NETMF.System 0x74883E49!=0xC032A004
Assembly: GHIElectronics.NETMF.IO (4.1.3.0) (212 RAM - 664 ROM - 289 METADATA)
TypeRef = 12 bytes ( 3 elements)
MethodRef = 4 bytes ( 1 elements)
TypeDef = 8 bytes ( 1 elements)
FieldDef = 4 bytes ( 2 elements)
MethodDef = 20 bytes ( 9 elements)
Strings = 212 bytes
Signatures = 33 bytes
ByteCode = 36 bytes
Assembly: GHIElectronics.NETMF.Hardware (4.1.3.0) (856 RAM - 5232 ROM - 3195 METADATA)
MethodRef = 44 bytes ( 11 elements)
TypeDef = 240 bytes ( 30 elements)
FieldDef = 92 bytes ( 46 elements)
MethodDef = 200 bytes ( 99 elements)
Strings = 1413 bytes
Signatures = 339 bytes
ByteCode = 494 bytes
Invalid native checksum: GHIElectronics.NETMF.Hardware 0xA1518A4B!=0x9C770BE2
Resolving.
Assembly: Microsoft.SPOT.Graphics (4.1.2821.0) needs assembly ‘Microsoft.SPOT.Hardware’ (4.1.2821.0)
Assembly: Project_Sample_2 (1.0.0.0) needs assembly ‘Microsoft.SPOT.TinyCoreRME’ (4.1.2821.0)
Assembly: Project_Sample_2 (1.0.0.0) needs assembly ‘Microsoft.SPOT.Graphics’ (4.1.2821.0)
Assembly: Project_Sample_2 (1.0.0.0) needs assembly ‘Microsoft.SPOT.Hardware’ (4.1.2821.0)
Assembly: Project_Sample_2 (1.0.0.0) needs assembly ‘Microsoft.SPOT.Touch’ (4.1.2821.0)
Assembly: Project_Sample_2 (1.0.0.0) needs assembly ‘GHIElectronics.NETMF.Hardware’ (4.1.3.0)
Assembly: GHIElectronics.NETMF.IO (4.1.3.0) needs assembly ‘GHIElectronics.NETMF.System’ (4.1.3.0)
Error: a3000000
Waiting for debug commands…
The program ‘[3] Micro Framework application: Managed’ has exited with code 0 (0x0).
[line]
Please guide further
This is because you have an old SDK with libraries version 4.1.3.0
The emailed test firmware only works with the newest libraries in the latest SDK. Libraries version 4.1.6.0
First download the latest SDK online. Update firmware, GHI references…etc until you get it working. There are update tutorials in the downloads section.
Next update the firmware with the emailed “test” firmware and try it…
Thanks Mike it is working now.
I have downloaded latest SDK and it is working with the firmware. I have tested my application and it is also working properly.
Thanks for the support.
