I am working with FEZ Cobra.
After I reinstall the latest GHI SDK, I get error message when add a reference:
Incompatible reference
“GHIElectronics.NETMF.Native, Version 4.1.5.0, Culture=neutral, PublicKeyToken=null” is incompatible with .NET Micro Framework 4.1.2821.0
In order to add it you should to change the project’s target to a compatible framework first.
You need to update the firmware on the EMX to the same version.
Run MFDelpoy (it’s in C:\Program Files\Microsoft .NET Micro Framework\v4.1\Tools )
Choose USB and click device capabilities, scroll up in the output window and look at the solution version. It needs to be 4.1.5.0.
Also if you are using an exsisting example, you need to delete all GHI references in the solution panel on the right and renew them (a copy is placed in the projects folder and needs updating )
First I uninstalled previous GHI SDK and check that SDK folders are deleted.
After that I installed the latest GHI SDK and update firmware on FEZ Cobra.
I made simple NETMF console project without GHI assemblies and deploy successfully to FEZ Cobra. When I try to add reference (GHI dll’s) I got that error.
I use Visual Studio 2010 ultimate with SP1.
