I am wondering, what would be the best idea for updating a window? I have a window with several bitmaps.
These bitmaps represent on or off state of objects. Once a object switches state, I would like to update the image too.
This window is the main window, so no window that can be opened by button.
Once the window is created, the bitmaps cannot change, since the window does not get closed. The only thing happening is that another window gets opened on top of it. (Visible = true)
How do I run some sort of update window function to update my bitmaps on the main window?
public class Main : Window
private static StackPanel stack_Title;
private static StackPanel stack_Content;
private static StackPanel stack_Window;
private static Bitmap settingsButton;
private static Bitmap joystickButton;
private Program _Program;
private static USBH_Mouse mouse;
private static USBH_Mouse keyboard;
private static USBH_Mouse joystick;
public Main(Program program)
_Program = program;
// Create a new stack panel, set margins, and bind it to the window
stack_Content = new StackPanel(Orientation.Horizontal);
stack_Title = new StackPanel(Orientation.Horizontal);
stack_Window = new StackPanel(Orientation.Vertical);
this.Child = stack_Window;
// Titlebar
TitleBar titleBar = new TitleBar("Foekie's Desktop");
titleBar.HorizontalAlignment = HorizontalAlignment.Left;
stack_Title.Children.Add(titleBar);
// Create a new window and apply the necessary properties
this.Height = SystemMetrics.ScreenHeight;
this.Width = SystemMetrics.ScreenWidth;
this.Background = new ImageBrush(Resources.GetBitmap(Resources.BitmapResources.background)) { Stretch = Stretch.None };
//add settings button
settingsButton = Resources.GetBitmap(Resources.BitmapResources.icon_Settings);
settingsButton.MakeTransparent(Color.Black);
Image image = new Image(settingsButton);
image.HorizontalAlignment = HorizontalAlignment.Left;
image.SetMargin(10, 10, 0, 0);
image.TouchDown += openSettings;
stack_Content.Children.Add(image);
//add joystick button
joystickButton = Resources.GetBitmap(Resources.BitmapResources.icon_JoystickOff);
joystickButton.MakeTransparent(Color.Black);
Image image2 = new Image(joystickButton);
image2.HorizontalAlignment = HorizontalAlignment.Left;
image2.SetMargin(10, 10, 0, 0);
stack_Content.Children.Add(image2);
//add title and content to the window stack.
stack_Window.Children.Add(stack_Title);
stack_Window.Children.Add(stack_Content);
static void updateWindow()
//Would it be possible with a method?
public void openSettings(object sender, TouchEventArgs args)
new Settings(_Program);
So this is the basic code. I have stripped out some junk, otherwise it would be way too big.
I would like to update the joystickButton object with a new image.
I refactored some of your names to match Microsoft’s coding best practices
Basically, you were storing the image that you use on the control as a field in your class, rather than the control. You want to re-use the control just changing the image, so i did that.
It also looked like you were wanting some sort of singleton pattern class so you just have one instance of MainWindow which you can reference from anywhere. Now you can just use MainWindow.Instance.whatever().
public class MainWindow : Window
public static MainWindow Instance { get; private set; }
StackPanel stackTitle;
StackPanel stackContent;
StackPanel stackWindow;
Image joystickButton;
Image settingsButton;
Program Program;
USBH_Mouse mouse;
static public MainWindow(Program program)
Instance = new MainWindow(program);
Program = program;
// Create a new stack panel, and add it to the window
stackContent = new StackPanel(Orientation.Horizontal);
stackTitle = new StackPanel(Orientation.Horizontal);
stackWindow = new StackPanel(Orientation.Vertical);
this.Child = stackWindow;
// Titlebar
stackTitle.Children.Add(titleBar);
// Apply the necessary properties
// add settings button
Bitmap settingsImage;
settingsImage = Resources.GetBitmap(Resources.BitmapResources.icon_Settings);
settingsImage.MakeTransparent(Color.Black);
settingsButton = new Image(settingsImage);
settingsButton.HorizontalAlignment = HorizontalAlignment.Left;
settingsButton.SetMargin(10, 10, 0, 0);
settingsButton.TouchDown += openSettings;
stackContent.Children.Add(settingsButton);
// add joystick button
Bitmap joystickImageOff;
joystickImageOff = Resources.GetBitmap(Resources.BitmapResources.icon_JoystickOff);
joystickImageOff.MakeTransparent(Color.Black);
joystickButton = new Image(joystickImageOff);
joystickButton.HorizontalAlignment = HorizontalAlignment.Left;
joystickButton.SetMargin(10, 10, 0, 0);
stackContent.Children.Add(joystickButton);
// add title and content to the window stack.
stackWindow.Children.Add(stackTitle);
stackWindow.Children.Add(stackContent);
public void UpdateWindow()
// Would it be possible with a method?
bool joystickConnected = true;
if (joystickConnected)
joystickButton.Bitmap = Resources.GetBitmap(Resources.BitmapResources.icon_Joystick);
// removed line so i could compile
//new Settings(Program);
Example of using a singleton.
MainWindow wnd = new MainWindow(program);
Thread.Sleep(5000);
// after 5 seconds change the joystick icon.
MainWindow.Instance.UpdateWindow();
static Program program;
public static Program Program
get { return MainWindow.program; }
set
MainWindow.program = value;
Instance = new MainWindow();
USBH_Mouse mouse;
static public MainWindow()
private MainWindow()
// Titlebar
// setting program initialises the class.
MainWindow.Program = program;
Thread.Sleep(5000);
set
public MainWindow()
USBHostController.DeviceConnectedEvent += DeviceConnectedEvent;
USBHostController.DeviceDisconnectedEvent += DeviceDisconnectedEvent;
// Titlebar
//image2.TouchDown += openSettings;
if (GlobalVariables.joystickConnected)
joystickButton = Resources.GetBitmap(Resources.BitmapResources.icon_Joystick);
static void DeviceConnectedEvent(USBH_Device device)
if (device.TYPE == USBH_DeviceType.Joystick)
Debug.Print("Joystick Connected");
MainWindow.Instance.UpdateLayout();
static void DeviceDisconnectedEvent(USBH_Device device)
Debug.Print("Joystick Disconnected");
GlobalVariables.joystickConnected = false;
Error:
[quote]A first chance exception of type ‘System.NullReferenceException’ occurred in FEZ Cobra Window Application.exe
An unhandled exception of type ‘System.NullReferenceException’ occurred in FEZ Cobra Window Application.exe[/quote]
set
I don’t see a MainWindow.program field anywhere, also the error is because Instance is null and you cannot set a property of something thats null
Firstly, copy my code for the button fields and mainwindow ctor - they have the fix you need.
no need to set the program variable in the update window - if you’re in that method you have an instance of the class already. UpdateWindow should be static. Can you email me your solution and i’ll fix it up/annotate my changes so you can see what i’ve done easier?
lol, my email address is all over the net. I don’t get any spam because i host with google apps I’ve been doing so for years, one of my email addresses was getting 400+ spam a day and i never saw one bit of spam in my inbox (only 60+ regular emails).
I’ll take a look at your solution tomorrow as it’s a bit late now. I don’t have a cobra so i cannot test it however i’ll run it through the in-brain-debugger
