Premium hardware
FEZ Spider Mainboard is premium hardware and FEZ Cerberus is open source hardware. I know from the (http://www.ghielectronics.com/offers) page what’s the difference, but i don’t know what that means?
Is this library already on chip, or not.
I am having a project with both mainboards which are connected through TCP. Does that mean, that i can use SQLite also on FEZ Cerberus (because i also buy Spider and i get premium stuff) or not?
It is board specific libraries that has certain features. Premium ONLY exists on premium boards. Even if you have both boards FEZ Cerberus will not have premium features.
The library is built into the product so SQLite is only available on spider for example.
Ou, that sucks.
I need only a few sensors and save it to SD card. The SQlite seems perfect thing to do that. 70€ more for that feature is a lot.
Using SQL Lite to save data from a few sensors is “overkill”, unless perfection is making a solution overly complicated. :slight_smile:
