Hello
I tried PPP with G120HDR board and CellularRadio module on User socket.
I use the code published in this thread.
Initialy I had the same problem as @ njbuch but I have modify Cellular_43.cs has indicated by @ 4egod and @ Dave McLaughlin and all is OK for me.
My program request every 2mn a server without problem since 1 hour.
I am in France with operator Orange.
I´m completelly new to this type of system and I´m trying to use this piece of software but as soon as I try to create a new âUseThisNetworkInterfaceâ including the new parameter I got errors related to the âserialâ object. Could you please tell me how to âfixâ the software?.
I just read @ ChristianJack - and I think the solution is to modify the mentioned file. Could somebody of you point me to where I can download this (or these) files?.
Make sure the serial port is open before you call the PPP functions. It will fail if not so.
in fact, you have to st the APN and then do the dialing before you call it so in theory the port must be open to do these but it may not be obvious the first time you use it.
With the code publish in this thread I have sometime two events cellularRadio_ModuleInitialized, and then two threads.
I have modify the code like this to take only one cellularRadio_ModuleInitialized event and to have only one thread to make the treatment. The code run fine. I have suppress all my code for display and publish only my code for CellularRadioâŚ
using System.Collections;
using Microsoft.SPOT.Touch;
using Gadgeteer.Networking;
using GT = Gadgeteer;
using G120 = GHI.Pins.G120;
using System.Net;
using System.Text;
using GHI.Networking;
using System.IO;
namespace G120MF43
public partial class Program
/// <summary>CellularRadio from modified class not the initial GHI class</summary>
private CellularRadio cellularRadio;
private bool m_cellularRadioInitialized = false;
private Thread m_requestThread;
private void RegisterExtenderSockets()
// The G120HDR has already 6 sockets, we create and register socket 7
var socket = GT.Socket.SocketInterfaces.CreateNumberedSocket(7);
socket.SupportedTypes = new char[] { 'I', 'K', 'U', 'X' };
socket.CpuPins[3] = G120.P0_10;
socket.CpuPins[4] = G120.P2_0;
socket.CpuPins[5] = G120.P0_16;
socket.CpuPins[6] = G120.P0_6;
socket.CpuPins[7] = G120.P0_17;
socket.CpuPins[8] = G120.P0_27;
socket.CpuPins[9] = G120.P0_28;
socket.SerialPortName = "COM2";
GT.Socket.SocketInterfaces.RegisterSocket(socket);
this.RegisterExtenderSockets();
cellularRadio = new CellularRadio(7);
NetworkChange.NetworkAvailabilityChanged += (a, b) => Debug.Print("Network availability changed: " + b.IsAvailable.ToString());
NetworkChange.NetworkAddressChanged += (a, b) => Debug.Print("Network address changed");
cellularRadio.ModuleInitialized += this.cellularRadio_ModuleInitialized;
cellularRadio.PowerOn(40);
void cellularRadio_ModuleInitialized(CellularRadio sender)
Debug.Print("ModuleInitialized");
if (m_cellularRadioInitialized)
return;
m_cellularRadioInitialized = true;
// Start a thread to request periodically the server
m_requestThread = new Thread(ThreadToRequest);
m_requestThread.Start();
private void ThreadToRequest()
Thread.Sleep(15000);
cellularRadio.UseThisNetworkInterface("orange.fr", "orange", "orange", PPPSerialModem.AuthenticationType.Pap);
while (cellularRadio.NetworkInterface.IPAddress == "0.0.0.0")
Debug.Print("Waiting on DHCP");
Thread.Sleep(1000); // (250);
Thread.Sleep(2000);
if (cellularRadio.NetworkInterface.IPAddress != "0.0.0.0")
while (1 == 1)
GetCounters();
Debug.Print("Hibernating");
Thread.Sleep(30000);
private const string GETURL = "http://myurltomyserver.com";
#region GetCounters
/// <summary>
/// Send a HTTP request to get counters values on serveur
/// </summary>
private void GetCounters()
string m_countersString = string.Empty;
try
Debug.Print("Send request");
// Send Http request
HttpWebRequest req = (HttpWebRequest)WebRequest.Create(GETURL);
req.ContentType = "text/json";
req.Timeout = 5000;
req.KeepAlive = false; // No keep the socket
// Retrieve response
HttpWebResponse resp = (HttpWebResponse)req.GetResponse();
// We examine only OK-200 Http response to avoid to display server error message
if (resp.StatusCode == HttpStatusCode.OK)
StreamReader sr = new StreamReader(resp.GetResponseStream());
m_countersString = sr.ReadToEnd();
sr.Close();
sr.Dispose();
resp.Close();
resp.Dispose();
req.Dispose();
Debug.Print("Server response : " + m_countersString);
catch (Exception ex)
if (ex.InnerException != null)
Debug.Print("GetCounters Error : " + ex.InnerException.Message);
#endregion
@ njbuch - The most visible result should be far fewer race conditions and missed data. PPP should be handled better as well.
As mentioned in your other thread, matching requests to responses and even returning that result from the original function is something on our list of improvements but that hasnât been done yet.
@ John - I watched the corrections. The event ModuleInitialized no longer exists, how to wait for the initialization of the module? What is the new way to manage the module, have you an example?
Thank you
@ ChristianJack - Previously, PowerOn would spawn a thread that would do the initialization. After it finished, it raised the ModuleInitialized event. Now, the module does all of that work in PowerOn, then returns. As soon as it does return, it is ready to be used.
As andre.m said, though, you want to watch the registration changed handlers to make sure you are connected to the network.
cellularRadio.GprsNetworkRegistrationChanged += cellularRadio_GprsNetworkRegistrationChanged;
cellularRadio.PowerOn();
and I put the previous code of cellularRadio_ModuleInitialized in the GprsNetworkRegistrationChanged event treatment.
I received never the GprsNetworkRegistrationChanged event.
If i use this code
cellularRadio.GsmNetworkRegistrationChanged += cellularRadio_GsmNetworkRegistrationChanged;
I received one time 2 or 3 the GsmNetworkRegistrationChanged event.
If I back to previous CellularRadio43.cs source with modification and previous initialization code
@ ChristianJack - You shouldnât put your code in the registration changed event handlers. In the old driver, ModuleInitialized was fired at the end of the thread PowerOn started. Since the thread body was moved into PowerOn, firing the event at the end no longer made sense. The return of PowerOn is now equivalent to the ModuleInitialized event.
If you do not always get the registration changed handlers, you can try to send the at command âAT+CREG?â. That should trigger the GSM event.
@ John - It is Ok for me now with this initialization code
void cellularRadio_GprsNetworkRegistrationChanged(CellularRadio sender, CellularRadio.NetworkRegistrationState networkState)
Debug.Print("Gprs status : " + networkState.ToString());
Thread.Sleep(40000);
Debug.Print("Init PPP");
Thread.Sleep(2000);
GetCounters();
-[quote] The return of PowerOn is now equivalent to the ModuleInitialized event[/quote].
I do not see that. If I suppress the Sleep(40000), the PPP initialization is made while the fixed green led on the CellularRadio module is off.
A question, during my first test I have received 2 or 3 time the following error: âSocketException ErrorCode = -1728053248â . I have not keep all the trace. Where can I find the explaination of this error code ?
John thank you for your help.
@ ChristianJack - Usually the socket error codes are around 10,000. Iâve never seen that specific code before. If you see it again and can get more information, we can look into it.
