In the robot I am building, I will be using a rechargable 9V battery to provide power to a Panda/Domino, and 4xAA rechargeable batteries to power dual low vottage motors using a DC motor controller sold by GHI.
I will be using one servo, which I purchased from GHI. The “standard” servo.
Since I will be driving the Panda with an external power supply, I assume that I can plug the servo into a component shield, after rewiring it to conform to the component shield JST pinout.
I would definitely power the servo(s) from a different power source. I have found servos can cause a voltage drop which will make will trigger your microcontroller’s low voltage cutout.
When working with servos I always try to have a seperate power supply, and its also important to make sure that all the powersupplies share a common ground.
