I’m using a barometer & usb-host-module to establish for communication with my android smartphone. When I start the fez spider by debugging it from visual studio, everything works fine: the connection to the android phone is established without problems. Hoverwhen I just start the spider without debugging, I have to reset it 100times bevor the connection works… Don’t know what’s wrong here… Do I have to change something at the configuration switches?
Do you have suggestion, for a power supply with batteries? Do I need any extra circuits or whatever? I’m asking because my barometer module still measures false values, but only when I use a battery (9V block battery).
I doubt a 9V battery can supply enough current for a mainboard, and if it could, it would not last very long, as most have a 200-300 mAh rating. They are not designed to discharge that quickly.
I’ve used a 9v to run my spider on plenty of occasions. Granted, it doesn’t last too long if I’m using more than a couple of modules, and it probably wouldn’t hold up well at all with numerous sensors, etc., but it seems to do fine for simple demos. If I need more, I typically switch to my wall wart.
I use a battery designed as a “USB emergency charger”, which works pretty well - mine is this one: http://www.amazon.co.uk/gp/product/B005JSG7GE/ref=oh_details_o03_s00_i01 - though I imagine there are any number of similar options that will supply USB-spec 5V for a reasonably high capacity (5600mAh). Also works powering Arduino, Raspberry Pi etc.
