When calling Power.Shutdown(true, rtc.Now + TimeSpan.FromSeconds(10)); on a PICO, Shutdown always fails with System.NotSupportedException.
Seems to be related to use of the WKUP pin. If Power.Shutdown() is called with wkupPIN=false, then Shutdown works.
Here’s some example code to demonstrate the problem.
Not using PA0 (WKUP) anywhere in example code.
Using Firmware 2.2.0.5100 on a PICO.
namespace Pico_Shutdown_Fails
internal class Program
static GpioPin _Button;
static GpioPin _Blue_LED;
static RtcController rtc;
static void Main()
rtc = RtcController.GetDefault();
rtc.Now = new DateTime(2023, 4, 12);
SystemTime.SetTime(rtc.Now);
_Button = GpioController.GetDefault().OpenPin(SC13048.GpioPin.PC13);
_Button.SetDriveMode(GpioPinDriveMode.InputPullUp);
_Blue_LED = GpioController.GetDefault().OpenPin(SC13048.GpioPin.PA8);
_Blue_LED.SetDriveMode(GpioPinDriveMode.Output);
while (_Button.Read() != GpioPinValue.Low)
Thread.Sleep(100);
_Blue_LED.Write(GpioPinValue.High);
_Blue_LED.Write(GpioPinValue.Low);
// ALWAYS fails with System.NotSupportedException when wkupPin=true
