This single line was working perfectly before upgrading to 4.1
After upgrading from 3.0 to 4.1 we are unable to load the project in debug, we have to comment this line for the projet to start and so our power management control is not available.
We have just examined the assemblies, the GHI version are 4.1.3.0 GHIElectronics.NETMF.Hardware
GHIElectronics.NETMF.Hardware.USBizi
I suppose that i have a problem related to the memory available, but i am unable to find the total footprint of my application before up-loading from VS2010 and looking to debug output.
Any idea to have a memory map or something alike before loading the assemblies, I know it seems a simple task but I didnt find the way to get that in VS.
Look at deployment messages in Visual Studio when you press F5. It shows how much memory each assembly takes and if there are any problems. What does it say?
sounds to me like you might need to check the firmware version you have on your Fez. Go thru the steps to deploy the latest one (from the latest GHI SDK you just installed) and make sure you start a new project and just put a minimal code in to test your use of PCON.
After updating the CLR with 15/10 everything went fine …
In fact as i am updating the firmawre from a virtual XP running on my x64 W7 and the file USBizi_CLR.GHI was an old one (never have files copy anywere ;=).
