Post CAN Connections throws Internal Server Error
Josh, as the topic says, my post http://www.tinyclr.com/forum/topic?id=8064 throws an Internal Server Error. What did I do wrong?
I tried to contact the webmaster@ tinyclr.com but got this error back:
Delivery to the following recipient failed permanently:
Technical details of permanent failure:
Google tried to deliver your message, but it was rejected by the recipient domain. We recommend contacting the other email provider for further information about the cause of this error. The error that the other server returned was: 550 550 No Such User Here" (state 13).
We wil get this resolved ASAP.
Also the menu item “My Posts” under forum throws that error :S
This was caused by placing code tags around repeative things like long lists of
Pos: 0 Bytes: 100 50 127 255 214 0 0 0 Hex: 64 32 7F FF D6 00 00 00
Pos: 1 Bytes: 129 3 32 252 223 0 0 0 Hex: 81 03 20 FC DF 00 00 00
Pos: 2 Bytes: 0 0 0 0 0 0 0 0 Hex: 00 00 00 00 00 00 00 00
Pos: 3 Bytes: 0 0 0 0 0 0 0 0 Hex: 00 00 00 00 00 00 00 00
This causes the code parser to break the page. I removed the tags and the post is visible again.
Thanks for fixing it Josh :wink:
