Excuse the messiness of the code below. I’m just messing around with auto-detecting USB cable connection, etc. Anyhow, if I instantiate ‘sd’ right before passing it to AttachLun everything works as expected and Windows sees the device/SD card. If I instantiate ‘sd’ in Main then when it is passed to AttachLun Windows ‘sees’ the SD card but it does not report the Volume label and it tells me the card is not formatted.
I guess in most usage cases you would already have the file system attached to the SD card so it would just be a matter of detaching the file system and passing it to AttachLun. I’ll try that next by instantiating ‘sd’ in Main and attaching the file system and then detaching the file system in my ‘attach’ method.
namespace Soigeneris
enum MassStorageState { Dissconnected, Connected, Attached };
static USBC_MassStorage ms;
static PersistentStorage sd;
static ExtendedTimer updateTimer; // checks to see if LCD requires an update every 100ms
static MassStorageState msState = MassStorageState.Dissconnected;
updateTimer = new ExtendedTimer(new TimerCallback(updateTimerHandler), null, 1000, 1000);
// Check debug interface
if (Configuration.DebugInterface.GetCurrent() == Configuration.DebugInterface.Port.USB1)
throw new InvalidOperationException("Current debug interface is USB. It must be changed to something else before proceeding. Refer to your platform user manual to change the debug interface.");
//sd = new PersistentStorage("SD"); // can't instantiate here
ms = USBClientController.StandardDevices.StartMassStorage(); // Start MS
// Assume SD card is connected
//PersistentStorage sd;
//try
// sd = new PersistentStorage("SD");
//catch
// throw new Exception("SD card not detected");
//// wait to connect to PC
//while (USBClientController.GetState() != USBClientController.State.Running)
// Debug.Print("Waiting to connect to PC...");
// Thread.Sleep(1000);
//ms.AttachLun(0, sd, " ", " ");
//// enable host access
//ms.EnableLun(0);
// Check USB cable connection state periodically
static void updateTimerHandler(object target)
USBClientController.State crap = USBClientController.GetState();
Debug.Print("State " + crap.ToString());
if (USBClientController.GetState() == USBClientController.State.Running
& msState == MassStorageState.Dissconnected)
Debug.Print("USB cable has been connected.");
msState = MassStorageState.Connected;
attach();
//else if (USBClientController.GetState() != USBClientController.State.Running
// & msState != MassStorageState.Dissconnected)
// Debug.Print("USB cable was unplugged!");
// msState = MassStorageState.Dissconnected;
//else if (USBClientController.GetState() == USBClientController.State.Running
// Debug.Print("USB cable is attached");
//else
// Debug.Print("USB Cable is not connected.");
// Attach to PC as mass storage device if SD card is inserted
static void attach()
Debug.Print("Making sure SD card is really there.");
if (PersistentStorage.DetectSDCard())
sd = new PersistentStorage("SD"); // instantiate here and it works?
ms.EnableLun(0); // enable host access
msState = MassStorageState.Attached;
Debug.Print("Attached as MassStorage device now.");
Debug.Print("Please Insert SD card!");
It looks the same either way… I am not what I missed.
Can you try something more simple in few lines of code and see if you have problems, like:
main()
sd = new PersistantStorage()…
StartMassStorage()…
AttachLun()…
EnableLun()…
Thread.Sleep(-1);
I also tried moving the AttachLun and EnableLun into a seperate static function and call it after instantiating sd and ms and it works fine. Seems to be related to be related to using the timer. If I dispose and newup sd again in my ‘attach’ method it works fine.
Another tidbit of information. I changed things around so that the ‘attach’ just sets a flag to indicates that the USB cable is connected. So the main thread just hangs out in a while loop until it sees the flag. This works! It has to be something related to trying to do this stuff via the timer thread even though the variables used are all in scope.
I wonder what would happen if I instantiate sd from the timer thread?
sd.MountFileSystem();
while (attached == false)
Debug.Print("Will now enable");
sd.UnmountFileSystem();
ms.EnableLun(0);
Edit: I have tried this again this morning and the USBClientController DOES indeed change when the USB cable is unplugged.
Here is something else I just noticed.
This: USBClientController.GetState(), will change state when the USB cable is plugged in, but not when the USB cable is removed. Full test program is below.
ms.EnableLun(0);
Debug.Print("State " + USBClientController.GetState().ToString());
Thread.Sleep(1000);
//Storage myStorage = new Storage();
//Thread.Sleep(Timeout.Infinite);
I’ve been playing with this again and it seems that IFF you call “PersistentStorage.DetectSDCard()” from a separate thread if screws things up. If I don’t call it the USBClientController state changes as it should. I think the only option I have not tried is declaring
in a separate class and instantiating them from the ExtendedTimer event in that same class. Then I could provide references to the main thread for the SD card or not depending on the USB cable connection state.
BTW, I have also noticed that you cannot have two ‘code’ tags in the same post.
Well, it is definitely something to do with calling DetectSDCard in the update timer thread. Interestingly enough I created a second timer that fires every 500ms and just have it update a flag to indicated if the SD card is inserted or not, it works fine. The test code is below, the basic idea is to be able to automatically detect the state of the SD card and USB connection so that events can be fired that other parts of the program can respond to.
using System.IO;
using Microsoft.SPOT.IO;
using GHIElectronics.NETMF.USBClient;
enum MassStorageState { Default, Connected, Dissconnected, Attached };
enum SDState { Default, Empty, Inserted, Removed };
public class Storage
static ExtendedTimer sdTimer;
static MassStorageState msState = MassStorageState.Default;
static SDState sdState = SDState.Default;
static bool sdInserted = false;
USBClientController.State lastState = USBClientController.State.Default;
public Storage()
throw new InvalidOperationException("ERROR: Current debug interface is USB!");
updateTimer = new ExtendedTimer(new TimerCallback(updateTimerHandler), null, 2000, 1000);
sdTimer = new ExtendedTimer(new TimerCallback(sdTimerHandler), null, 1000, 500);
USBClientController.State newState = USBClientController.GetState();
if (newState != lastState)
Debug.Print("State " + newState.ToString());
lastState = newState;
// SD card inserted so mount file system
if (!sdInserted & sdState == SDState.Default)
Debug.Print("SD card has not yet been inserted, first pass");
sdState = SDState.Empty;
else if (sdInserted & sdState != SDState.Inserted)
Debug.Print("SD card has been inserted");
sdState = SDState.Inserted;
else if (!sdInserted & sdState == SDState.Inserted)
Debug.Print("SD card has been removed");
try
catch
Debug.Print("SD file system was not moounted");
sd.Dispose();
sdState = SDState.Removed;
USBClientController.State USBState = USBClientController.GetState();
if (USBState != USBClientController.State.Running & msState == MassStorageState.Default)
Debug.Print("USB Cable has not yet been attached");
else if (USBState == USBClientController.State.Running & msState == MassStorageState.Dissconnected)
Debug.Print("USB cable has been connected");
attach();
else if (USBState != USBClientController.State.Running & msState == MassStorageState.Connected)
Debug.Print("USB cable has been dissconnected");
void attach()
if (sdState == SDState.Inserted)
Debug.Print("SD Card is not inserted, cannot create MSD");
void sdTimerHandler(object target)
sdInserted = PersistentStorage.DetectSDCard();
We cannot reproduce the problem here. It could’ve been a simple bug in your C# application.
If you can make a small application that reproduces the problem, we can look into it.
Here is a simple example, there are two methods of attaching the lun. Comment/uncomment the proper lines to use either ‘attach1()’ or ‘attach2’. If you use ‘attach190’ you must re-new sd or it will not actually create the mass storage device properly. If you just don’t use the ‘PersistentStorage.DetectSDCard())’ method as shown in ‘attach2()’ then it works fine.
using System.IO;
namespace SDDetectError
ms.AttachLun(0, sd, " ", " "); // uncomment for attach2
USBClientController.State state = USBClientController.GetState();
Debug.Print("State " + state.ToString());
if (state == USBClientController.State.Running
//attach1(); // comment out one of these and use the other
attach2(); // to use attach2 you must also uncomment the ms.attach line in Main()
static void attach1()
// re-new SD here and you'll get a mass storage device
sd.Dispose();
static void attach2()
This is still working fine here. Where do you see the problem? Of Course if you eject and insert the SD card, you will have problems because this is not handled in code…
Other than this, maybe DetectSDCard messing up the SD card you are using try other brands.
If you comment out the ‘sd.dispose’ and the ‘sd = new’ then the attach one method will not work. I’m not removing/reinstalling the SD card. The SD card is inserted, the program is run in debug mode, and the USB cable is plugged in.
To avoid confusion of what to comment out for each attach method, here is the version that exhibits the problem.
To duplicate error
Plug in SD card
Run program in debug mode
Plug-in USB cable
Using this method I never see the FEZ appear properly as an MSD. If you let it set for about a minute a dialog box pops up on the PC that says the device must be formatted before it can be used. I’m using VS2008 Pro, the GHI Beta SDK, and Win7 with a Transcend 2 GB uSD card.
This could be an issue with a particualr uSD card BUT if I call ‘PersistentStorage.DetectSDCard’ in a seperate thread then everything is fine. If you do all of this in the same function, i.e. don’t use the timer thread, it works fine. The problem seems to be when calling ‘PersistentStorage.DetectSDCard’ in the same timer thread that the ms.attach in done in.
using System.IO;
Thank you, we found the problem.
The first time DetectSDCard() runs, it resets the SD card power, so it messing it up.
Put this at the start of your program and it should fine.
Cool! I had tried all sorts of combinations to determine the problem but had not hit on that. It explains why when I was calling PersistentStorage.DetectSDCard(); in a separate timer thread, that fired twice as often as the main timer thread things worked properly. Now I can rework my class that fires events when the state of the SD card and/or USB Client state.
