Guys,
I’m trying to port some Arduino libraries over to C# however, my knowledge of both languages is not at an expert level (yet).
The library i’m trying to port uses bitClear and bitSet from the Arduino.
bitSet: [url]http://arduino.cc/en/Reference/BitSet[/url]
bitClear: [url]http://arduino.cc/en/Reference/BitClear[/url]
Are these functions available in C# NetMF ?
Also, it uses micros() from arduino, is this equal to DateTime.Now.Ticks ?
Thanks in advance.
I want to set the third bit in my variable called x
x |= (1<<2);
that is hte same as
x= x |(1<<2);
set this first fit?
x|=(1<<0);
now to clear the forth bit
x &= (~(1<<3));
Is this what you need?
not sure…
bitClear:
[italic]Description[/italic]
Clears (writes a 0 to) a bit of a numeric variable.
[italic]Syntax[/italic]
bitClear(x, n)
[italic]Parameters[/italic]
x: the numeric variable whose bit to clear
n: which bit to clear, starting at 0 for the least-significant (rightmost) bit
[italic]Returns[/italic]
none
bitSet:
Sets (writes a 1 to) a bit of a numeric variable.
bitSet(x, n)
[italic]
Parameters[/italic]
x: the numeric variable whose bit to set
n: which bit to set, starting at 0 for the least-significant (rightmost) bit
[italic]
Returns[/italic]
none
Yes that was exactly what I showed you
void bitSet(int x,int n)
x |= (1<<n);
This might be a handy thing to have as an extension method so you could just do something like:
myVar.BitSet(2);
myVar.BitClear(3);
//or even
myVar.Mask(0xF0); // which just does a logical AND
Thanks Gus,
So, bitClear will be:
void bitClear(int x, int n)
x &= (~(1<<n));
right?
