Hello,
I am trying to populate a drop down list on the T43 screen with all of the available wifi networks. I am using a raptor, RS21, and T43 on NETMF4.3.I am scanning ok and can see the networks if I manually debug the specific numbers. I am having trouble with the code to populate the Glide.List with a for loop to add object from an array list. I cannot figure out how to run a for loop with the number of available networks and turn that into a dropdown list on the screen. Below is my code, which I know isn’t correct but will help demonstrate what I am trying to do.
Thank you,
Jordan
if (scans != null && scans.Length > 0)
/*ArrayList options = new ArrayList()
new object [2] {"SGW", scans[0].Ssid}
for (int i = 0; i < noofnetworks; i++)
new object [2] {scans[i].Ssid.ToString, scans[i].Ssid}
list = new List(options, 150);
