Png file as resource prevent to deploy
If I insert a png file in a resource file, it prevents to deploy, but message when deploying says “check your hardware”.
I know that png are not supported but it can be useful (if possible) to display a message when attempting to add such a file, or when it is deployed.
Does the size make any difference?
Png file is about 540 bytes. And just one prevents to deploy.
Do you want I test with bigger file ?
No need thanks. We will try on our end.
Lets start making issues https://github.com/ghi-electronics/TinyCLR-Samples/issues/43
You are right: forum will be cleaner. Thanks to do it :beer:
Any news about this one ?
The issue is still present in preview3 (which is kind of logical since the issue is in the backlog).
This is very low priority to honest. This shouldn’t prevent anyone from doing whatever they need, which is why it is low priority.
