Hi all i need to deploy user application into usbizi using serial port.
Is it possible and how?
please Help
Yes, that will work with a RS232 to TTL level converter and setting the mode pin.
If you want to use GHI modules, you can combine these 2:
RS232 Module: http://www.ghielectronics.com/catalog/product/355
and the extender module (to solder wires to your USBizi board): http://www.ghielectronics.com/catalog/product/273
