What you guys think of this idea.
Anyone use SharkBite connectors for plumbing before?
How about same idea for header pins for quicker prototypes and no solder of header pins during dev stage. Say you want to do a proto-board. But don’t want to commit to solder or bboard first. The PinByte would be like the back of a ear-ring connector. You would press it over the pin under the board and it “grabs” the pin and pulls it tight to the board. The PinByte would have pad that presses against the bottom pad for contact. Contact would also be made on the pin itself. Could make a new line of headers, hookup wire, and boards all designed these quick (but sturdy) ideas.
