Pin Capture
I’m trying to use PinCaputre (GHIElectronics.NETMF.Hardware.PinCapture) on a socket in order to read a PWM signal on an extender.
Firstly, I’m a chancer, but I’d be grateful if anyone had an example of this?
And, how do you associate or access a particular socket and pin in order to use the PinCapture?
Thanks in advance for any help with this - it would be a great example.
:slight_smile:
Is this on spider?
sorry - yeah it’s the spider.
If you want to get a particular pin from a socket, you should be able to use this:
GT.Socket.GetSocket(socketNumber, true, null, null).CpuPins[pinNumber]
Hope this helps!
Thanks - works a treat.
Now to read the pin.
Got it. I’ll paste the code here in case someone else can use it. If anyone has suggestions for better code then please share - I’m new to C# - and not a great coder either!
public partial class Program
        GHIElectronics.NETMF.Hardware.PinCapture ranger;
        static uint[] readings = new uint[1];
            GT.Socket socketEight = GT.Socket.GetSocket(8, true, null, null);
            ranger = new GHIElectronics.NETMF.Hardware.PinCapture(socketEight.CpuPins[3], Microsoft.SPOT.Hardware.Port.ResistorMode.Disabled);
            readRanger();
        void readRanger()
            ranger.Read(true, readings, 0, readings.Length, 3000);
            double readingMicro = double.Parse(readings.GetValue(0).ToString());
            double conversion = (readingMicro / 147) * 2.54;
            int roundedCM = (int)conversion;
            Debug.Print("Distance: " + roundedCM);
shapingstuff,
Is that for an ultrasonic range finder?
Yeah - the calculation is for a maxbotix ranger in particular.
