PermanentUserKey not working
Not supported on ChipworkX…
Thanks bad… now I have to figure out how to store a serial number.
We are porting the EMX code on to ChipX. And EMX had it
Maybe EWR
EXR was not reliable on 4.0. So I am not sure.
Was anything improved on 4.1
EWR should work well for small settings… Since you just need a key, it should work fine.
EWR had problems because developers used it extensively as a general area to store data, but in your case it should be fine.
Since I cannot use Battery back RAM in ChipX. I want to use to store all my settings.
There are around 80 values that has to be stored.
What I have seen is. At some power ups the EWR re-initlilizes and all settings are lost
I don’t think there are problems with EWR. Try it on 4.1 and use Microsoft SDK’s example as guide…
