I recently got code working with the DS1307 RTC, but I now need to get a PCF8563 working. The code should be similar, only some addresses changed, but I keep getting errors when I try to read the chip. I’m using SDK 4.3 and VS 2013.
The error message is
A first chance exception of type ‘System.ArgumentOutOfRangeException’ occurred in mscorlib.dll
An unhandled exception of type ‘System.ArgumentOutOfRangeException’ occurred in mscorlib.dll
This is when I try and read the date time.
Any help would be appreciated.
using Microsoft.SPOT.IO;
using GHI.Pins;
namespace P3_2
InputPort LDR0 = new InputPort(FEZPandaIII.Gpio.Ldr0, false, Port.ResistorMode.PullUp);
OutputPort LED1 = new OutputPort(FEZPandaIII.Gpio.Led1, false);//Blue
OutputPort LED2 = new OutputPort(FEZPandaIII.Gpio.Led2, false);//Blue
OutputPort LED3 = new OutputPort(FEZPandaIII.Gpio.Led3, false);//Blue
OutputPort LED4 = new OutputPort(FEZPandaIII.Gpio.Led4, false);//Blue
P3_2.RTC_8563 RTC_time = new P3_2.RTC_8563();
RTC_time.SetControlRegister();
//Set the date and time
RTC_time.SetDateTime(new DateTime(2015, 1, 4, 7, 20, 34, 30));//year,month,day of week(0-6),day,hour,minute,second
while(LDR0.Read())
Debug.Print(RTC_time.GetDateTime().ToString("G"));
LED1.Write(!LED1.Read());
Thread.Sleep(5000);
and the class
namespace P3_2
class RTC_8563 : IDisposable
private I2CDevice I2C;
I2CDevice.I2CTransaction[] xaction;
ushort PCF8563_Address = 0x51;
public void Dispose()
I2C.Dispose();
xaction = null;
public RTC_8563()
//Create I2C object
I2CDevice.Configuration conf = new I2CDevice.Configuration(PCF8563_Address, 100);
I2C = new I2CDevice(conf);
public void SetControlRegister()
xaction = new I2CDevice.I2CTransaction[2];
xaction[0] = I2CDevice.CreateWriteTransaction(new byte[] { 0x00 });//control reg zero
xaction[1] = I2CDevice.CreateWriteTransaction(new byte[] { 0x00 });//write data 0
if (I2C.Execute(xaction, 1000) == 0)
new Exception("Failed to send I2C data");
public DateTime GetDateTime()
xaction[0] = I2CDevice.CreateWriteTransaction(new byte[] { 0x02 });
byte[] ReturnedDateTime = new byte[7];
xaction[1] = I2CDevice.CreateReadTransaction(ReturnedDateTime);
int secs = bcdToDec(ReturnedDateTime[0]) & 0x7f;
int mins = bcdToDec(ReturnedDateTime[1]) & 0x7f;
int hours = bcdToDec(ReturnedDateTime[2]) & 0x3f;
int days = bcdToDec(ReturnedDateTime[3]) & 0x3f;
int weekdays = bcdToDec(ReturnedDateTime[4]) & 0x07;
int month = bcdToDec(ReturnedDateTime[5]) & 0x1f;
int year = bcdToDec(ReturnedDateTime[6]) + 2000;
DateTime dt = new DateTime(year, month, days, hours, mins, secs);
return dt;
public void SetDateTime(DateTime datetime)
xaction = new I2CDevice.I2CWriteTransaction[1];
byte[] sb = new byte[8] { 0x02,
decToBcd(datetime.Second),
decToBcd(datetime.Minute),
decToBcd(datetime.Hour),
decToBcd((int)datetime.DayOfWeek),
decToBcd(datetime.Day),
decToBcd(datetime.Month),
decToBcd(datetime.Year - 2000)
xaction[0] = I2CDevice.CreateWriteTransaction(sb);
private byte decToBcd(int val)
return (byte)((val / 10 * 16) + (val % 10));
private byte bcdToDec(byte val)
return (byte)((val / 16 * 10) + (val % 16));
