Steven, sure.
this one is only working for about 5 button presses, after that the camera is busy and won’t work anymore :
using Microsoft.SPOT.Touch;
using Gadgeteer.Networking;
using GT = Gadgeteer;
namespace GadgeteerApp1
public partial class Program
GT.Timer timer = new GT.Timer(2000);
// Initialize event handlers here.
// e.g. example.Pressed += new GTM.ManufacturerName.ExampleModule.EventHandler(example_Pressed);
button.ButtonPressed +=new Button.ButtonEventHandler(button_ButtonPressed);
button.ButtonReleased += new Button.ButtonEventHandler(button_ButtonReleased);
camera.PictureCaptured+=new Camera.PictureCapturedEventHandler(camera_PictureCaptured);
timer.Stop();
Debug.Print("Ready to go");
if (camera.CameraReady)
Debug.Print("Camera is ready.");
camera.TakePicture();
Debug.Print("Camera is busy.");
void button_ButtonReleased(Button sender, Button.ButtonState state)
//throw new NotImplementedException();
void camera_PictureCaptured(GTM.GHIElectronics.Camera sender, GT.Picture picture)
display.SimpleGraphics.DisplayImage(picture, 0, 0);
void button_ButtonPressed(GTM.GHIElectronics.Button sender, GTM.GHIElectronics.Button.ButtonState state)
if (button.IsLedOn)
timer.Stop();
timer.Start();
button.ToggleLED();
and this code works fine with the camera (streaming), however the picture is full of yellow stripes, colors are partly messed up. The touch screen is fine, so my guess the camera is damaged.
Bitmap fullSize;
Bitmap midSize;
Bitmap halfSize;
int testStep;
GTM.GHIElectronics.Camera.PictureResolution FullSize = GTM.GHIElectronics.Camera.PictureResolution.Resolution320x240;
GTM.GHIElectronics.Camera.PictureResolution MidSize = GTM.GHIElectronics.Camera.PictureResolution.Resolution176x144;
GTM.GHIElectronics.Camera.PictureResolution HalfSize = GTM.GHIElectronics.Camera.PictureResolution.Resolution160x120;
camera.CameraConnected += new GTM.GHIElectronics.Camera.CameraConnectedEventHandler(camera_CameraConnected);
camera.BitmapStreamed += new GTM.GHIElectronics.Camera.BitmapStreamedEventHandler(camera_BitmapStreamed);
camera.PictureCaptured += new GTM.GHIElectronics.Camera.PictureCapturedEventHandler(camera_PictureCaptured);
button.ButtonPressed += new GTM.GHIElectronics.Button.ButtonEventHandler(button_ButtonPressed);
fullSize = new Bitmap(FullSize.Width, FullSize.Height);
midSize = new Bitmap(MidSize.Width, MidSize.Height);
halfSize = new Bitmap(HalfSize.Width, HalfSize.Height);
// Do one-time tasks here
Debug.Print("\r\n*** Camera Test ***\r\n");
Debug.Print("Note that this test expects a camera in socket , a display and a button in socket .");
Debug.Print("Wait a moment...");
switch (testStep)
case 0:
camera.StopStreamingBitmaps();
camera.CurrentPictureResolution = MidSize;
camera.StartStreamingBitmaps(midSize);
Debug.Print("Camera should be streaming medium sized images (176x144) to the center of the display.");
Debug.Print("Press button to continue.");
break;
case 1:
camera.CurrentPictureResolution = HalfSize;
camera.StartStreamingBitmaps(halfSize);
Debug.Print("Camera should be streaming half sized images (160x120) to the display, above and left of center.");
break;
case 2:
camera.CurrentPictureResolution = FullSize;
Debug.Print("Streaming from the camera has stopped.");
Debug.Print("Press the button again to take a full-sized picture.");
break;
default:
Debug.Print("Picture taken. Press button to take another...");
break;
testStep++;
void camera_BitmapStreamed(GTM.GHIElectronics.Camera sender, Bitmap bitmap)
switch (testStep)
case 0:
display.SimpleGraphics.DisplayImage(bitmap, 0, 0);
break;
case 1:
display.SimpleGraphics.DisplayImage(bitmap, display.Width / 2 - (uint)MidSize.Width / 2, display.Height / 2 - (uint)MidSize.Height / 2);
break;
case 2:
display.SimpleGraphics.DisplayImage(bitmap, display.Width / 2 - (uint)HalfSize.Width, display.Height / 2 - (uint)HalfSize.Height);
break;
void camera_CameraConnected(GTM.GHIElectronics.Camera sender)
Debug.Print("Camera test has started - camera should be streaming full size (320x240) to display");
testStep = 0;
camera.StartStreamingBitmaps(fullSize);
