Can anyone tell me where to locate the project done with the Parallax compass and the FEZ Domino? I have tried to look at each tinyclr web page, but I am either overlooking it or in the wrong place.
Are you looking for someone who has completed the code to talk to it already? Or are you looking to post a compass based project? I has because I plan on coding for the HMC6352 you can get from parallax i just haven’t gotten to that point.
Thanks for the code. I have ordered the compasses from Parallax. Any thoughts on calibration? I will be working on calibration, when I get my compasses.
from previous experience with it make sure you calibrate with all electronics you will be running on it. In the last build i used mine in motor noise was a issue i had to mount it away from the chassis. The calibration routine should be simple to code you send a command then run through the turning in circle twice in 10 seconds i think. In the long run i had it 8" away from the motors and had to write a delay in the reading. that was with the basic stamp and propeller so the delay may not be needed with FEZ.
Well, I think the device was pre-calibrated at the factory.
I didn’t go through calibration on mine as I tested it with another compass for comparison and it was right on the money.
But, let me know how your’s goes. I have the RP-5 robot base and drove it around with the compass sending data. With and without the motors running I got the same reading.
Right now I am controlling my robot base with a WiFly device and my own software. I use TeraTerm to send commands (f55 - Forward 55%, r40 - Right Turn 40%, etc). It works great controlling it from my WiFi network and PC. I am in the process of writing a function (h125 - turn to a heading of 123 deg) or whatever heading that is entered.
