Hi all,
Just wondering if the panda (not the panda II) has a real-time clock.
If not, what would you recommend using?
Thanks.
qin__23
Hi all,
Thanks.
qin__23
No it doesn’t have RTC, FEZ Panda II does.
Welcome to the community.
there’s another thread here asking about the same thing - the chip is capable of having an RTC added but requires direct soldering to the chip pads - not a simple task and not for the faint hearted but achievable. I haven’t done so (yet - I’m still a chicken )
You’d have to solder a crystal directly to the chip pads, as well as a VBAT connection for power to the RTC. Certainly not for amateurs.
Also there are a lot of errata on how to use VBat pin. Check that if you want a reliable battery backed RTC.
Thanks all.
I’ll look into the ds1307.
qin__23
