I’ve searching around quite a bit regarding this topic, but can’t find any helpful Infos.
How do setup the Panda III for serial deploy/debug? I want to use it as CDC device …
As far as I understand I need an FTDI cable, but to which pins to I have to connect the serial port wires on the Panda and what else do I have to setup? The user manual say nothing regarding this topic.
Thanks for any help…
This is the standard USB cable (Mini connector by the LDR0 button).
//You need the GHI drivers installed for the Universal Serial Bus devices.
Poor wording on my part for the line above:
For a COM1 serial port to the PC.
Using a USB FTDI 3.3V cable for serial. (PC using Tera Term)
Pin
1 Black Ground To 8 pin header GND
(Arrow Mark on connector)
2 Brown CTS# (Not used)
3 Red VCC (+5V) (Not used)
4 Orange TXD To 8 pin header COM1 RX D0
5 Yellow RXD To 8 pin header COM1 TX D1
6 Green RTS# (Not used)
Just a tip, start with USB debugging and move to serial debug. First test your FTDI cable with a simple serial test app to make sure you get that working before you step off into serial debugging It would be hard to diagnose if you have UART Dyslexia or not unless you have working diagnostics.
Thanks for the tips, I already played some time with USB debug/deploying (Controlling Servos via PWM), now I want to move on and command the Panda from a PC where to move the servos - thats why I wanted to get serial Debugging on and use CDC for PC <-> Panda communication.
FTDI seems to work - using one of the CDC example I get “Hello World!” on COM5 on the PC regular The only Problem I’ve seen so far is that if the data sent by the Panda is not ‘consumed’ on the PC after a while there is an exception thrown. But that should be no big issue to handle.
