Im new to FEZ panda. I have a FEZ panda and a Arduino ethernet shield. But i can’t get my ethernet shield online.
I have tried with a static ip, and a dhcp configuation and i have used wireshark to see any network traffic from it… But nothing happens… Even not arp packes can i see in wireshark with it.
And there are light on 100M led, and link LED, and sometimes RX led is blinking…
I use the following code in VS2010:
using GHIElectronics.NETMF.Net.Sockets;
using GHIElectronics.NETMF.Net.NetworkInformation;
using System.Text;
using Socket = GHIElectronics.NETMF.Net.Sockets.Socket;
namespace FEZ_Panda_Application7
try
byte[] ip = { 192, 168, 5, 25 };
byte[] subnet = { 255, 255, 255, 0 };
byte[] gateway = { 192, 168, 5, 1 };
byte[] mac = { 0x00, 0x88, 0x98, 0x90, 0xD4, 0xE0 };
WIZnet_W5100.Enable(SPI.SPI_module.SPI1, (Cpu.Pin)FEZ_Pin.Digital.Di10, (Cpu.Pin)FEZ_Pin.Digital.Di9, true); // I have tried with Di7, and Di9..
NetworkInterface.EnableStaticIP(ip, subnet, gateway, mac);
NetworkInterface.EnableStaticDns(new byte[] { 192, 168, 5, 1 });
//Dhcp.EnableDhcp(mac, “smgethernet”); // I have also tried to use this without the static ip settings…
catch (Exception)
Debug.Print("fail");
I hope you can tell me what i’m doing wrong here…
