OutputPort Object
Here’s a quick question… What reference should I add and also use to make use of the OutputPort Object??? I ask only because for some reason, I can’t get it to recognise the Object
Cheers
TC
I have found that if I’m not sure what reference to add for a certain method sometimes the .NETMF API reference will provide enough information, sometimes not. If you type the method call in correctly and try to build, you’ll get an error but many times the error will tell you what reference you need to add.
I think for the OutPut port you’ll likely need both Microsoft.Spot.Hardware and Microsoft.Spot.IO
The Microsoft.Spot.Hardware reference.
See this link:
[url]Microsoft Learn: Build skills that open doors in your career
Make sure to check the Microsoft NETMF API Reference ([url]Microsoft Learn: Build skills that open doors in your career) if you do not know what to add.
If you are unsure about GHI specific items, please make sure to check out the GHI Electronics NETMF Documentation ([url]http://ghielectronics.com/downloads/NETMF/Library%20Documentation/Index.html[/url])
As found on the downloads page ([url]http://www.tinyclr.com/dl/[/url])
