When i try use the IO53, IO54 and IO55 like outputport the compiler inform: CLR_E_PIN_UNAVAILABLE
The USBIZI User manual inform on page 10 that the IO51 … IO60 are General purposes digital I/O
Some fix to this ?
code:
OutputPort LCD_Enable = new OutputPort((Cpu.Pin)USBIZI_IO.IO53, true);
LCD_Enable.Write(true);
LCD_Enable.Write(false);
Compiler messages:
Ready.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Micro Framework\v4.1\Assemblies\le\mscorlib.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.Native.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.Hardware.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files\GHI Electronics\GHI NETMF v4.1 SDK\Assemblies\le\GHIElectronics.NETMF.System.dll’
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files\GHI Electronics\GHI NETMF v4.1 SDK\Assemblies\le\FEZDomino_GHIElectronics.NETMF.FEZ.dll’
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files\GHI Electronics\GHI NETMF v4.1 SDK\Assemblies\le\GHIElectronics.NETMF.Hardware.dll’
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Users\Rafael\Desktop\Orbisonic AM Simples\Orbisonic AM Simples\Orbisonic AM Simples\bin\Debug\le\Orbisonic AM Simples.exe’, Symbols loaded.
OI
#### Exception System.Exception - CLR_E_PIN_UNAVAILABLE (1) ####
#### Message:
#### Microsoft.SPOT.Hardware.Port::.ctor [IP: 0000] ####
#### Microsoft.SPOT.Hardware.OutputPort::.ctor [IP: 0006] ####
#### MFConsoleApplication1.Program::Main [IP: 000e] ####
A first chance exception of type ‘System.Exception’ occurred in Microsoft.SPOT.Hardware.dll
An unhandled exception of type ‘System.Exception’ occurred in Microsoft.SPOT.Hardware.dll
